Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 10-02-2007, 07:22 AM
TempzCrown TempzCrown is offline
Send a message via AIM to TempzCrown Send a message via Yahoo to TempzCrown
Hollowing out Cats...Pros and cons?
I have a 1993 cvpi and i was wondering how my car would react if i hollowed out the catalytic converters.I cant tell for sure but it seems that a stronger air flow should be coming out my pipes so one of my cats could be clogged.I know all about the laws and in my county,emissions are not required.....yet,but if i did hollow them out,would i see a dramatic increase in HP?? Thanx for ur help
Old 10-02-2007, 11:34 PM
biggbabysweetz1's Avatar
biggbabysweetz1 biggbabysweetz1 is offline
Re: Hollowing out Cats...Pros and cons?
you would be better off just removing it if your going to hollow it out. and yes he increased air flow will help your performance and mileage slightly but remember to follow emissions laws (that your country may put into effect)
or invest in a high flow converter.
talk to a local scrap dealer as well if you go the route of removing your cat, a cat here that isnt 100% clogged goes for about 100 bucks because of the precious metals inside.
Suck squeeze
Bang Blow
Old 10-10-2007, 05:01 PM
slash09 slash09 is offline
removing your cats might set off the check engine light and you honestly might not be able to tell any difference in hp. plus even with no emission law usually if your car came with it it has to be there.
Old 10-10-2007, 11:03 PM
reekor reekor is offline
Georgia is in the United Stated, as are it's counties. Every heard of federal emissions laws?
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 10-11-2007, 12:18 AM
Davescort97 Davescort97 is offline
Escort guy
If you do hollow the converters make sure you get it all. If you don't have them completely free of material they will continue to break up inside and will plug up your mufflers. If that happens whatever you gained will be lost and you'll be out the price of 2 mufflers.
Old 10-24-2007, 06:14 PM
pollenjesus pollenjesus is offline
It sounds tempting to take the cats off...don't do it.
1. Your exhaust will stink...enough so that a keen police officer can tell that you don't have cats.
2. Excessive noise. The cats supress noise levels more than you might think....but hey if you wanna make a lot of noise run straight-pipes from the mainfolds back. The drone will be killer around 50-60 mph; forget about listening to your radio.
If your cats are plugged get a good aftermarket high-flow replacement. Magnaflow makes pretty good replacements although they won't be direct bolt-ons.
