Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Audio and Videos
Old 10-01-2007, 09:20 PM
hahapopcorn hahapopcorn is offline
this amp with this sub?
Sorry if this is a dumb question, i don't know crap about audio stuff. But my concern is i just ordered a sub but i don't know if i should get a new amp with it also, the ohms thing has me concerned because there was two types of alpine type-r's...a dual 2 ohm and dual 4 ohms.
Amp: Audiobahn A2401T
Channels
Amplifier TypeDual ChannelAmplifier Output2-channel
Power
Peak Power100 Watts x 2Output Details100 Watt - 4 Ohm - 2 channel(s), 140 Watt - 2 Ohm - 2 channel(s), 280 Watt - 4 Ohm - 1 channel(s)
Features
ColorsChromeHigh Pass Frequencies50 - 750 HzLow Pass Frequencies30 - 120 HzResponse Bandwidth10 - 40000 HzBass Boost Frequency45 HzBass Boost Gain0 to +18dBCrossover Slope18 dBDistortion Factor0.02 %
Sub: Alpine Type-R SWR-1522D 15" Subwoofer Dual 2-ohm Coils
Peak Power Handling :2000Watts
RMS Power Range :75-750Watts
Impedance: ( Ohms )2
Dual Voice Coil: Yes
Sensitivity: 89dB
Frequency Response:22-1KHz
Cone MaterialKevlar-reinforced pulp cone Surround MaterialCast aluminum frame with perimeter venting Size15"
will these work ok?
1995 Talon TSi AWD
Current: 6-bolt, Big 16g Turbo, Blitz carbon face boost/air/fuel gauges, Act 2600, Evo VIII enkei rims, GReddy Type-RS BOV, K&N filter, DSMLink, Apex'i n1 exhaust w/ 3" down pipe, OBX short shifter, Turbo XS MBC
Soon To Come: 20g turbo, 750cc FIC, 255 lph Walbro, GReddy FMIC, AEM EBC
Old 10-01-2007, 10:44 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: this amp with this sub?
Dude, answering that question is like me asking you this question:
Will this black Ace Hardware bolt go with this Hardware Hank shiney looking nut?
We're going to need a few specifics before we can point you in the right direction homie.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 10-01-2007, 11:05 PM
How should i specify it more? o.O
1995 Talon TSi AWD
Old 10-01-2007, 11:42 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
With a dual 2-ohm speaker your amp is going to have to run at 1 or 4ohms. I would get look for an amp that is 1 ohm stable. And also make sure that the rms power are pretty close between the to.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 10-02-2007, 03:01 AM
Thor06's Avatar
Jizzed In My Pants
Well considering before all you had was a brand and model number for each.... and I'll be damned if I am going to go look around for that when its you that needs to know.
Still need a tick more info like what the sub is rated for RMS. Thats not entirely necessary yet, but when you start looking for a bigger amp it will be.
And yes, that amp *could* work, but its horribly underdriven for that big ass 15" speaker. 280W RMS (peak doesnt mean shit) for that much sub is kinda rediculous, my 10" MTX thunder 8000 is driven by I think 290W RMS and it bumps pretty good, but its also got less than half the surface area. I'm guessing that sub can take probably atleast 600 RMS and I would look for atleast 500 for it if I were you.
Old 10-02-2007, 07:57 AM
Holset powered 420a
Your going to need a bigger amp, that amp isint designed to push a sub. Look for something that is 1 ohm stable and can push around 800rms at 1 ohm.
Here is a good amp, not sure on your price range though. I assumed you wanted to stick with audiobahn.
http://www.cardiscountstereos.com/ca...ct+%23=A8001DT
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 10-02-2007, 03:33 PM
rickyrickster25's Avatar
rickyrickster25 rickyrickster25 is offline
Thumbs up Re: this amp with this sub?
Or, you could buy an Alpine amp... I have a 600 watt Alpine amp, and it has blown an explode, but that was just for fun, lol, and it also pushes my 12 pretty good. My opinon is if your getting a type-r sub, go with an Alpine amp, they are nice.
97' Eclipse RS 5 Speed 420A
Under The Hood:
Bomz UDP, Custom CAI, NGK Plugs, Mopar Wires
Interior:
Blue Glow Dash Guages & HVAC Controls, Neon Accents, Custom Dash Work\Paint, Alpine Type-R/JL Audio System, Custom Trunk Layout
*GOAL* - Prove Him Wrong
Originally Posted by UnderEstimate Me
I doubt bolt-ons will get you to 160hp on the 420a. Unless you have some dyno sheets Im calling bs.
Old 10-02-2007, 03:43 PM
Hmm i see so this set up will not work at All? or will it just not reach the potential of the sub?
1995 Talon TSi AWD
Old 10-02-2007, 03:59 PM
Wink Re: this amp with this sub?
Ok im not trying to be a dick or anything, maybe this will put it into perspective, right now you are trying to power your sub with way too little energy, you just dont have enough power being produced to power that sub to the point where its going to be worthwile to have set up. Its kind of like trying to start a forest fire during a flood, its just not going to happen, lol.
Under The Hood:
Interior:
Old 10-02-2007, 04:12 PM
Lol yeah i get the picture..but a couple more things...even though they won't seem all that great will it work in general? and even if they did work is it BAD to underpower the subs with a crappy amp?
1995 Talon TSi AWD
Old 10-02-2007, 04:23 PM
Holset powered 420a
Yes it can be bad to under power a sub. That amp you were looking at is more for powering speakers. Your looking for more of monoblock class D amp.
If you used that low powered amp your going to be pushing it so hard to try and drive that sub its not going to be good. When you max an amp out like that you loose a little bit of sound clarity.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 10-02-2007, 05:11 PM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
You don't have to go with a class D amp. I prefer a class AB amp for a sub anyday. To each his own. I really don't know anything about audiobahn amps. But yeah like home dude a few posts up said, Alpine makes nice amps. Great amps for your money. Plus they don't try and bullshit you with big numbers to get you to buy them (like most brands do, pioneer for example). Alpine amps put out what they advertise.
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 10-02-2007, 06:47 PM
That crappy little audiobahn is what i have and what i used to power my 15 inch fosgate (an older one forgot wut model) it worked pretty good with that...but anyways, so if i max out my amp is the amp the only thing that will mess up? or will the subs go to crap too? Sorry this is the last question lol thanks all of you for the info and advice.
1995 Talon TSi AWD
Old 10-02-2007, 07:30 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
The sub will physically "put out" sound with that amp, but it won't be anywhere near sounding like it should with an amp rated to put out what that sub takes. Running an amp at maximum power isn't good for them because you can risk overheating and ruining the whole amp, on the other hand, underpowering a sub will not ruin it within a week, but over time it really starts to take a toll on the inners of the sub, therefore running the risk of blowing it.
That should clear up your questions.
95 Talon TSI AWD
97 Eclipse GST
Old 10-03-2007, 09:49 PM
Yea so i would honestly go with an alpine amp, lke i said there 600 is one of their smaller amps and it can max out my 12" type-r, which isn't a whole lot different then yours, basically just a bit smaller. If you really feel like you dont know what you are doing, go to best buy, they carry alpine amps, and they will be able to steer you in the right direction, and they have pretty great prices when it comes to that kind of thing too. You can also go to alpines website, http://www.alpine-usa.com/US-en/products/ it is a great site, and they are really good at getting back to you quickly if you have a question. It is also very detailed on specs and stuff of their products, but their online prices are outrageously over. I have a deck from them that is MSRP'd on the website for over $500, and i paid like $230 for it at best buy, i also got my amp there to and my sub..... great place for alpine products, and like vanilla gorrila said, you actually get what you pay for.
Under The Hood:
Interior:
