Old 10-01-2007, 08:35 PM
tgathings tgathings is offline
replaced a 305 with a 350
I was wondering if I need to replace the computer if I change the motor from a 305 to a 350
Old 10-02-2007, 07:34 PM
2000CAYukon 2000CAYukon is offline
Re: replaced a 305 with a 350
The computer is the same, but the PROM is different.
Take a look at http://www.tbichips.com/faq.htm
//2000CAYukon
Old 10-03-2007, 05:44 PM
Thanks for the information, I will see about getting the parts to complete my project.
Old 10-07-2007, 02:15 PM
Cadillakin'98's Avatar
Cadillakin'98 Cadillakin'98 is offline
What parts are you talking about getting? Most of your accessory parts (alternator, waterpump, etc,) are interchangable between the 305 and 350.
Old 10-07-2007, 08:03 PM
The previous message, I was told that I needed to change my injectors, electronic spark control and the prom chip
Old 10-07-2007, 09:38 PM
If the 350 is mostly stock, the injectors and electronic sprak control can be reused from the 305. The 350 Prom is a good idea since the fuel requirements for the 350 are different from the 305.
//2000CAYukon
Old 10-07-2007, 11:37 PM
I'd research the injectors. Look to see if they have the same part #. If not then yes I would definantley change the injectors. The 350 probably does require more fuel displacement than a 305.
Old 10-09-2007, 12:27 AM
Looks like the 350 injectors are different from the 305. The F-body guys have been doing 305 to 350 swaps for a while.
See http://www.thirdgen.org/techboard/tb...-350-swap.html
//2000CAYukon
Old 10-09-2007, 09:24 AM
webbch webbch is offline
If you live in an area that requires emission testing, be aware that you *may* not pass emissions with the larger motor. It will also be difficult to sell later on for the same reasons.
I almost bought a silverado a couple years back that had a 5.7L in it, but the owner had changed the motor from a 4.3L to the 5.7L, and it wouldn't pass emissions testing because the VIN identified it as having emissions associated with the 4.3L (one could argue that perhaps the 5.7L wasn't set up correctly either). Just something to think about - I'm not an expert on emissions, so perhaps there's something that can be done there.
2003 Honda Odyssey EXL (3.5L)
2002 Volvo V70 X/C
1990 Chevy Silverado K2500 (5.7L TBI)
