Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Exterior | Wheels | Tires
Exterior | Wheels | Tires This is the place for all exterior modifications including wheels and tires.
Old 10-01-2007, 06:41 PM
masonyes masonyes is offline
removing paint yourself?
my 1980 475 horsepower despertly needs a paintjob. I think someone started it but never finished, cuz theres primer on it. But anyways scraping the paint off with a sander sounds pretty easy to do and I was wondering if an ordinary person without any experince of body work/painting cars could do it?
plus i've heard alot of bad things about using chemicals to strip the paint? would you like to comment?
Old 10-01-2007, 06:43 PM
blindeyed's Avatar
blindeyed blindeyed is offline
eBay aDdict™
Send a message via AIM to blindeyed
Re: removing paint yourself?
A dual-action sander would work fine (uses a compressor). Makes quick work of the job. You can find them at lowes/home depot along with the stick on sand paper.
- Jason
1995 Pontiac Firebird
User Guidelines | VB Codes Explained | AF Merchandise
"Each of us, is in the scheme of things, insignificant.
But millions of insignificant people, doing a tiny bit,
can add up to be a very significant force."
Old 10-01-2007, 08:01 PM
79Bandit's Avatar
79Bandit 79Bandit is offline
i had a 93 honda civic a couple of years ago and me and the pals just got out there and used eletric sanders and went two work took us about 3 1/2 hours and it was a job well done. not hard at all you see the paints then you dont.
Old 10-03-2007, 04:50 PM
Firebirdlad03 Firebirdlad03 is offline
Send a message via AIM to Firebirdlad03
take some 80 grit and a dual action sander (known as a DA)and ur good to go
Mitch
92 Firebird formula...
Old 10-09-2007, 07:28 AM
brass_monkey93 brass_monkey93 is offline
the only bad thing about using the DA is if you are inexperienced with it you can make the paint uneven and then when you paint you will see waves in the body. I would practice on a few junkyard fenders first just to get the hang of it
future mods:
Pacesetter Headers
Magnaflow Exhaust
Jet Performance Chip
Ram air hood w/ functional air box
