Old 10-01-2007, 05:34 PM
jeff983000gt's Avatar
jeff983000gt jeff983000gt is offline
clutch issue????
hey..i was driving my 98 3000gt..no issues, no warning signs, but all the sudden..i was backing my car up..ironicly to put up for sale..and all the sudden the clutch just fell to the floor! there is about 1" of play in the clutch now..i dont even know if its drivable..i dont know what it is..i had the clutch changed about 4000 miles ago..a few ideas i thought were maybe low fluids? or a slave or master cylinder? idk..trannys arnt my specialty..any ideas?
2000 trans am WS6
FTP 85mm intake
85mm jet maf
85mm summit throttle body
85mm bbk ssi intake
fast fuel rails
30lb ford racing injectors
spohn strut bar
msd ignition coils
msd 8.5mm spark plug wires
edelbrock shorty headers
upgrade cam/ port and polished heads
SMG dyno tuned ( 375 rear wheel hp )
magnaflow cat back
slp y pipe
umi bolt on subframe connectors
umi rear control arms
umi panhard bar
4:10 rear end gears
stage 2 spec clutch
Old 10-01-2007, 05:41 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: clutch issue????
Check the resevoir. Its problably empty. Chances are your slave is shot.
Old 10-01-2007, 07:03 PM
well i did check my resovoir right after it happened..it was the first thing that came to my mind..and easiest to check..its missing about an inch of fluid off the top..which is quite a bit considering its a small resovoir..im betting its the slave too..well see when i tow it to my machanics tomorow..
2000 trans am WS6
FTP 85mm intake
85mm jet maf
85mm bbk ssi intake
fast fuel rails
spohn strut bar
msd ignition coils
magnaflow cat back
slp y pipe
umi panhard bar
4:10 rear end gears
stage 2 spec clutch
