Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 10-01-2007, 04:56 PM
inatalonIXLR8 inatalonIXLR8 is offline
Question 1st Gen pistons
Are the tops of stock 1st gen pistons perfectly smooth or are they somewhat grainy ? I just had a look and can't see any obvious pitting, and the lettering and numbers stand out looking clean without any carbon build up. Compression was excellent 145/150/150/150, so I'm starting to like what I see with this 95 GST for sale!!
95 Talon Tsi AWD 5spd
2.4L4G64 6bolt JE8.5EagleTorqueplatedFully ballanced-balanceshaftARP Ferrea1mm 1Ghead ported/polished HKS264/272 fidanzagears turbonetics copy polished GT3076R VbandTial38mm cometic prothane mounts SARD850 stage4 Compclutch+flywheel 3"exh Walbro255 rewired Innovate wideband O2 ForgeBOV Autronic standalone innovative wideband[url=http://img494.imageshack.us/my.php?image=talonandhelicopter5as.jpg]
Old 10-01-2007, 06:14 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: 1st Gen pistons
Yes, the pistons are somewhat bumpy, not perfectly smooth like forged ones.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 10-01-2007, 07:47 PM
Re: 1st Gen pistons
Right on!!!!!!! Just laid my deposit on her. The car drives in first and reverse (flipped through the other gears, but not while cruising) but chatters and clunks every quarter turn of the wheels. I'm kind of leaning towards the Quaiffe LSD. You think ?
Old 10-01-2007, 11:18 PM
Thor06's Avatar
Jizzed In My Pants
Re: 1st Gen pistons
As the problem for the chatter and clunk? I wouldnt suspect so. Those bitches are like a grand, I cant imagine one taking a shit and I would imagine if thats what went, it wouldnt move at all. As far as why it might be messing up every quarter turn, I am not sure, but I am pretty sure you are going to need a new/rebuilt tranny . It sounds like you might have a stripped gear or something and the shards are getting into the gears and making a bad time, but regardless its going to need a rebuild or a new one.
Old 10-02-2007, 01:23 AM
Re: 1st Gen pistons
I hope you're right. The Quaiffe is more expensive than the tranny. Can the tranny be removed and replaced with the engine still in ? Or is it necessary to extract the whole engine ?
Old 10-02-2007, 03:16 AM
Thor06's Avatar
Jizzed In My Pants
Re: 1st Gen pistons
No sir, engine can (and should) be left in. I've never done it for a FWD, but I think it should be pretty close to the same. If you want more detailed directions, poke around a bit, PM someone, or get a Haynes manual, but all you should need to do is pull off the passenger side wheel, unbolt the strut from the spindle and take that big ass nut off the axle, work the axle out of the spindle hole and pop it out. Then do the same for the other side. Remove any cross members in the way and other things in the engine bay in the way of unbolting the tranny (i.e. IC pipes, vac hoses, speedo cable, etc, etc). Support the tranny from underneath and take off the motor mount. Unbolt it from the motor and carefully wedge it apart. Then, with someone steadying it, lower the bitch out the bottom.
Old 10-02-2007, 10:35 AM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Re: 1st Gen pistons
You can do it without removing the engine. You just remove it from the passenger side, you just have to remove all that suspension and crap from the passenger side and you can slip it out there.
You don't have to take apart the drivers side like the passengers. You just need to be able to slip the axle out.
1991 GSX 2.3 Stroker
