Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 10-01-2007, 04:54 PM
streetcar streetcar is offline
'97 Buick Park Avenue fuel sender wrench
Who knows where to get an affordable wrench to remove the locking ring from the fuel tank sending unit? This one's too tight for the hammer method.
Old 10-02-2007, 05:43 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Red face Re: '97 Buick Park Avenue fuel sender wrench
I don't know what is affordable to you but, This One is the only one I have seen. This would not be affordable to me!
Old 10-03-2007, 09:00 AM
Isn't this a crime how car makers force people to their shops for repairs by having such expensive special tools. You are right - that is not affordable. I found one for $127 and thought that was crazy. And then how do you know it is really the right one?
Old 10-29-2007, 02:04 PM
dksram
Guest
Posts: n/a
Hammer method will work.I though mine was welded on.I used a 10 pound hammer with an old 6" long 1/2" extension.Just be sure not to hammer the same tab and rotate to each tab.Believe me,it will come loose.
Old 10-29-2007, 02:40 PM
maxwedge maxwedge is offline
A990 racer
Use a brass punch here to avoid sparks.
Old 10-29-2007, 06:27 PM
I was hoping to avoid taking the tank off to be able to get a straight shot with a punch/hammer. The access hole in the trunk leaves little room to get a good angle for pounding it loose. I think I will make a wrench.
Old 10-29-2007, 10:19 PM
Blue Bowtie's Avatar
Registered Offender
I've had reasonable success using two pairs of Chan-Nel-Lock pliers to walk the ring around after soaking with B"Laster PB. I don't recall ever having to hammer on an in-tank unit locking ring, but we only get road salt for six months out of the year around here, so other areas might be worse.
Old 03-02-2008, 07:38 PM
kawal kawal is offline
Did you ever get your sender unit replaced? I can help with the wrench and the sender unit if you are still waiting to fix it.
It's best to email me, because I don't check the forum that often.
Ray Kawal
Sequim, WA
Old 03-02-2008, 07:48 PM
HotZ28's Avatar
AF Moderator Elite
Thanks for the post; however this thread is beyond the 3-month time frame for posting. Please read: Posting in Closed or Outdated Threads-PA
Closed Thread
