Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 10-01-2007, 03:09 PM
Gere Gere is offline
help with a transport
it is a 1994 transport it use to run but evry now then it would stall. if you turn off the key then restarted it , it would be fine untill the next time. but now it starts and runs for a few sec(2-5) then stalls. it will not start untill you turn off the key and then restart it ( cycle the ign) but then it will only run for a few sec. then stall again but if you cycle the ign it will do it all over again please help it is my mother van
if someone can help me please email at [email protected]
thank you Gere
Old 10-01-2007, 04:20 PM
maxwedge maxwedge is offline
A990 racer
Re: help with a transport
Welcome to AF. Check the fuel pressure for starters.
Old 10-02-2007, 10:29 AM
guido0136 guido0136 is offline
Is your check engin light on?
Old 10-02-2007, 06:42 PM
something is shutting the pump and injector off I by pass the oil pressure and it stills does it
Old 10-08-2007, 07:24 PM
dorkdriver2 dorkdriver2 is offline
Check the resistance of the fuel injectors. 12-13 ohms= good. 0-1 ohms= bad
Old 10-14-2007, 12:47 AM
docnice docnice is offline
I need to know what to do about my climate control switch does not go all the way up to the number 4 blower. It only goes from 1 to 3. I own a 1993 Pontiac Transport 3.8 litre engine. I need to know if it is the heater control relay switch or thermostatic switch?
Old 10-14-2007, 08:12 AM
LMP's Avatar
LMP LMP is offline
I kind of understand position 1,2,3 work, but on position 4, blower does not, right? Or you have a fully automatic climate control, which may be somewhat different (not documented in my '93 manual...); anyway, check high speed relay, in engine compartment. THis is the relay that works the fan on max speed only.
www.avigex.ca/xport/heaterrelay.jpg
mmm...this topic could have been started as a new thread, on in one that already dealt with climate control....however I agree that this thread title is rather vague anyway and can apply to everything...
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
Old 10-20-2007, 11:07 AM
divemaster divemaster is offline
You mean the switch does not physically turn or the fan does not operate? If the fan does not operate on #4 - replace the resistor board - under the glove box behind the blower fan...
