Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 10-01-2007, 01:23 PM
Bjorntaler Bjorntaler is offline
Rolling the Montana Engine Forward
Is this difficult to do for a Shade Tree Mechanic? Any special considerations? Like don't do this or make sureyou do this first!!
I would like to change the plugs and wires on my 2000 MOntana.
Old 10-01-2007, 11:26 PM
chris_eitniear's Avatar
chris_eitniear chris_eitniear is offline
Send a message via Yahoo to chris_eitniear
Re: Rolling the Montana Engine Forward
I've changed the plugs and wires in my 2000 Montana before. Its a rough job, but doable. I think the only tool I had to go out and buy was a set of ratchet straps to pull the engine forward with. The hardest part of the job, for me, was getting the plug wires off the back three plugs. All three were stuck on tight and I wound up having to split the boots with a pocket knife while draped over the motor and cussing at GM.
There are quite a few things to take apart before you can actually get to the point of rolling the engine forward and getting at the back three plugs. If you can, you may want to note how everything came apart so it can go back together the same way.
EDIT: I'd recommend using AC Delco plugs. I've read that other brands don't last too long in GMs and this is a job you're probably not going to want to do more than once.
'07 Buick Lucerne
'99 Jeep Wrangler
'65 Ford Mustang Coupe
Old 10-02-2007, 12:45 AM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
It also helps to use a little anti-seize on the threads of the plugs and a little di-electric grease on the spark plug boots so they will be easier to remove again, if the need arises.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 10-02-2007, 01:33 AM
Yep, you're right on that one. I did that even though I changed the plugs and wires at 110k miles. I shouldn't have to do it again, but just in case...
'07 Buick Lucerne
'99 Jeep Wrangler
Old 10-02-2007, 06:34 AM
hufhouse's Avatar
hufhouse hufhouse is offline
The Haynes Manual has step-by-step instructions for rolling the engine forward. If I could do it, anybody can do it.
Old 10-04-2007, 11:19 AM
Thanks for all the help I will be attempting this weekend.
Old 10-06-2007, 12:56 PM
wafrederick wafrederick is offline
Banned
It is horrible and you might want to buy the special tool to move the engine forward called a GM engine moving forward tool.Any Cornwell,Mac,Matco or Snap On dealer sells this tool.Some parts stores sell it too.
Old 10-07-2007, 06:38 AM
hufhouse's Avatar
Huh?
Old 10-07-2007, 11:29 AM
Originally Posted by hufhouse
Huh?
Make that two. I had good luck using ratchet straps. I parked behind another vehicle and hooked the straps to the frame of that one and to the loops on the engine and ratcheted the straps tight. Worked fine for me.
'07 Buick Lucerne
'99 Jeep Wrangler
Old 10-07-2007, 04:03 PM
hufhouse's Avatar
This has got to be sarcasm. It has been over a year ago, but I think I just removed the front mounts and the two throttle cables, put a ratcheting strap on the lift hook and the front rail and ratcheted it forward. Easy as pie.
Old 11-07-2007, 12:15 PM
Nole Chick's Avatar
Nole Chick Nole Chick is offline
This has got to be sarcasm...
Nope, it's for real. Did a quick search and found Lisle makes one as well as Thexton. Costs around $40.
Old 11-20-2007, 07:40 AM
electro452 electro452 is offline
Anything need unbolted underneath from the exhaust system ? I need to roll the engine on my 2000 montana to change the air solenoid and don't really want to have to purchase the Haynes Manual to learn how to move the engine. Anyone done this that can provide a brief list of items that need disconnected besdies the throttle cable and mounts?
Apprecaite everyones time on this thread....
Old 11-24-2007, 08:41 AM
hufhouse's Avatar
From "Haynes Repair Manual" #38036 for 1997-2001 Venture, Silhouette, Trans Sport and Montana (which you oughtta buy because it also gives really clear pictures of everything and saves you a ton of time and you can keep it for the next thing that goes wrong) :-)
1. Block the rear wheels, place the transaxle in neutral and disconnect the cable from the negative terminal of the battery. Caution: on models equipped with the Theft-lock audio system, be sure you have the correct activation code before disconnecting the battery.
2. Remove the air cleaner duct and air cleaner. Also remove the accelerator cable and the cruise control cable from the throttle body.
3. Remove the two bolts and detach the driver's side torque strut from the vehicle. Remove ONE bolt from the radiator side of the passenger side torque strut and pivot the passenger side torque strut towards the engine.
4. Attach a ratcheting strap to the front of the radiator support and to the engine lifting eye on the driver's side strut bracket, the ratchet the strap to tilt the engine toward the radiator side.
Old 11-24-2007, 11:48 AM
Thanks hufhouse. Were seeling the car the first of the year so I didn't want to invest in a book at the end of the race.....thanks for the information.....It's been a good ride for over 7 years but it's time for a new vehicle..
Old 11-24-2007, 05:48 PM
JabbaTHutt JabbaTHutt is offline
So what you are telling me is that if I put a new battery in my van the radio is gonna need a code to make it work again?
Where do I get this code from for a 2003 montana?
2003 Montana EXT
Most options
Niagara Falls
Canada
