Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 10-01-2007, 10:18 AM
bleedEGLblue's Avatar
bleedEGLblue bleedEGLblue is offline
Over Bore Question
Since a hole was punched thru piston #1 in my car I figure might as well over bore. Just wondering if you guys have an estimate to see if I can fit it in my budget. Also where do yu get this done, performance shops? Anyone know of anywhere in the North Minneapolis area?
Live From The Great State of Hockey
93 Eagle Talon Tsi
Rebuild TTD:
Ross Racing Pistons(.20 over) - comp 101200's - Head Rebuild Kit - Port/Polish - Big 16g ported Internal WG 34mm - DNP Tubular Exhaust Mani - Megan Racing O2/Outlet - Apexi DP - Walbro 255 - 660cc's - Venom FR - JDM FMIC - Link - Apex'i timer - Short Throw - OEM TB - -6 Fuel Line - FPR - Water/Meth Injection - GM MAF
Previous Mods: GReddy type-rs BOV, 2.5" exhaust, ED Drifter BodyKit, Python security
Old 10-01-2007, 10:33 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Over Bore Question
Take the block to a machine shop to get it bored. Not real sure on a price, I wouldn't think it would that high though.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 10-01-2007, 10:34 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Yellow pages Holmes.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 10-02-2007, 07:47 PM
NOFX0617's Avatar
NOFX0617 NOFX0617 is offline
Send a message via AIM to NOFX0617
Yeah I think i paid like 10 or 15 bucks a cylinder to get it bored out to .020 over. Machine work is pretty inexpensive. I would just find a machine shop in your area and have them look at it. Depending on how bad your cylinder walls are you may not be able to bore it out that much...
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
Walbro 255 fuel pump
GReddy Type S BOV
Turbo XS Boost Controller
Balance Shaft Elimininator
ACT 2600
RRE 11lb No Name Flywheel
Prothane Motor Mounts
Tokico Illuminas Advanced Handling Kit
RRE Front and Rear strut tower bars
RMDSM Front and Rear Sway Bars
TRE Stage 2 Tranny
ARP Head Studs, Main Studs, Rod bolts
Old 10-03-2007, 12:30 PM
So lets say I get down there and the walls arnt up to par. Do i have to scrap the whole part?
93 Eagle Talon Tsi
Rebuild TTD:
Old 10-03-2007, 01:09 PM
Holset powered 420a
You will be fine unless the walls are just extremely bad. Which in your case I highly doubt.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 10-03-2007, 01:57 PM
Alright thanks again
93 Eagle Talon Tsi
Rebuild TTD:
Old 10-07-2007, 05:36 AM
kjewer1 kjewer1 is offline
AF - Advisor
That sounds awefully cheap for overboring. If you find a shop that does DSM motors often there is a better chance they'll have a torque plate for the 4g63. Bore as little as possible (according to the .020"/.5mm increments) so you get as many rebuilds out of that block as possible. Up to 060 over you're alright, that's essentially the stock bore size of the 2.4 liters. Over that it get riskier. At ~700 whp+ people have cracked cylinder walls on 2.4s 020 over.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 10-09-2007, 10:23 AM
Sorry to bring back an older topic ...
I know that .020" is not a lot of change but does this play with thefuel injection at all??? Should I ned any mods to maintain power after boring?
93 Eagle Talon Tsi
Rebuild TTD:
Old 10-09-2007, 11:04 AM
AF - Advisor
Your EMS will never even know you made the change.
Kevin Jewer
Old 10-09-2007, 11:31 AM
Thor06's Avatar
Jizzed In My Pants
Yeah, you only gain about 23.5cc of displacement when you bore .020" (.5mm) over.... thats .023 of a liter.
