1998(155K miles) Blazer Tune up
I've changed the plugs,wires,and PCV valve( first time) and will change the cap,rotor,fuel filter,and O2 sensor for first time.I've had injectors cleaned once quite awhile ago.Anything else?What is recommended for fuel injector cleaner?It runs pretty good and gets about 18-20 miles per gal.Thanks.
Re: 1998(155K miles) Blazer Tune up
I've alway's got good results from using Chevron fuel injector cleaner (Black Bottle).......
(Fuel Filter Tip) A lil dab of anti seize on the threaded end of the new fuel filter before the install will be a big time saver nextime for you... How's your air filter? You do not have to do this, but I Flush Out the Cooling System and do a Fluid Exchange on the transmission with a new filter every two years on my 1998. This truck runs like brand new....
1998 BLAZER LS Vin-W 4Dr 2wd 2004 Cavalier LS 4Dr 2.2 Ecotec "Good Part's ain't Cheap--Cheap Parts ain't Good" |
Thanks!
