Old 09-30-2007, 09:29 PM
S13Driftfiend's Avatar
S13Driftfiend S13Driftfiend is offline
Send a message via AIM to S13Driftfiend
In-dash fold out question
whats up guys i just finished installing my in dash last night and i thought i had a solution to the override problem (driving while a movie is playing). i was told to wire the e-brake safety wire (from back of reciever) to the power antenna wire of the wiring harness. i also (obviously) hooked the power antenna wire from the reciever to the power antenna of the wiring harness. so in the end, i soldered the power antenna and ebrake wires (from reciever) to the power antenna wire of the harness (three way splice). now, not only does it not work when im driving, when the truck is in park and the ebrake is engaged it still reads "it is unlawful to drive with screen in view and pull the ebrake up blah blah blah.."
does anyone know how i could fix this, maybe another way to wire it to override the safety feature? i know it can be done, just need some direction. sorry for the huge post, thanks
SHIFT_S i d e w a y s
Originally Posted by slideways...
you fail at life. go back into your mom's uterus and de-evolve into the nut stain i left on her sheets.
Old 10-01-2007, 12:22 PM
PlayStation3 PlayStation3 is offline
Re: In-dash fold out question
you didn't here it from me, but you need to either ground it or look on ebay for a module type thing that people use for boat installs.
Old 10-01-2007, 04:12 PM
just any ground? ill try it and see what happens. i also heard i could cut into the ebrake wire and just put an inline switch in so i could make the car think the ebrake is up while im watching movies although it isnt? thanks for the help
Old 10-01-2007, 05:45 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
that lead needs to be grounded (as stated above), you have connected to 12V instead
Old 10-01-2007, 06:38 PM
i just went out to play with it, held the wires in place and it worked, went to wire them, try it again and it didnt. so correct me if im wrong, but...
-the ebrake wire (from ebrake) should be grounded
-the ebrake wire (from reciever) should meet that wire at the ground?
thanks PaulD, from what i hear you know your stuff when it comes to this.
Old 10-02-2007, 02:40 AM
the one from the reciver needs to be grounded to complete the circuit. grounding the ebrake might work but i can see it f up stuff like abs and the brake light will always be on. what in dash are you using?
Old 10-02-2007, 05:55 AM
ok, so the ebrake wire just stays where it is, attached to the button under the lever?
Old 10-02-2007, 05:58 PM
Audio Guy
yea, when you raise up on the ebrake it lets the switch up - that grounds the wire going to it.
Old 10-02-2007, 06:19 PM
i tried that, it didnt work. heres what i did... i wired the ebrake wire (from the deck) to the ebrake wire (under the ebrake lever). it worked beautifully. i soldered everything, put the car back together (turning the key and trying it and it worked after every screw i put in) until i went to run the engine to charge the alternater... blue screen. when the key is in acc, it works. when the car is running, it doesnt. any ideas?
Old 10-02-2007, 06:45 PM
sickcallawayc12's Avatar
sickcallawayc12 sickcallawayc12 is offline
Do you have an automatic tranny? I wired mine to what I thought was the parking brake switch wire (for the tranny) and not my parking/e-brake pedal deal in my Blazer. I dunno if it was the right wire though. The only time it doesn't play DVDs is when i use the brake pedal (by the gas). Plays DVDs when i'm driving (which i would never do) as well as in Park. Weird.
1998 Chevrolet Blazer LT (95% stock)
Pioneer AVH-P7500 DVD receiver
12" Alpine Type-R in a sealed box
PIAA Super Plasmas GT-X bulbs
PIAA Xtreme White bulbs
K & N drop-in filter
"Melo" and "AI". Enough said.
Old 10-21-2007, 10:23 PM
dbfreak147.5 dbfreak147.5 is offline
those things are easy to trick if it is a jensen i have the bypass code
if not hook the ground up to a momentary switch button thing off the ground
or ground the wire, unground, and ground again
2 Orion HCCA 10'S
2 AudioPipe 3k's
Adam Whitehead
