Old 09-30-2007, 09:03 PM
jrpiecemind jrpiecemind is offline
miss fire
i have a 95 jimmy 4.3 W installed new cam sensor, 2 new knock sensors, map sensor, 2 O2 SENSORS, NEW THROTTLE POSITION SENSOR. NEW COIL new plugs, rotor, cap, wires, new spider,new fuel pump and this animal still idles rough and missfires and sets 300 code can anybody help
Old 09-30-2007, 10:40 PM
BigBlue77 BigBlue77 is offline
Re: miss fire
Have you done a compression test? If so, what did you come up with? You said it is rough at idle, does it smooth out as the RPM's increase?
Old 09-30-2007, 11:07 PM
Blue Bowtie's Avatar
Registered Offender
Re: miss fire
I've had P0300 DTCs generated when three rocker arm studs were pulled off the heads. Obviously, it idled poorly and ran rough.
It's not always a sensor or ignition component. Like BigBlue advised, check the mechanical condition of the engine.
Old 10-01-2007, 03:46 PM
Re: compression
does anybody know what what the cylinder compression should be on 1995 jimmy 4.3 W with 20.000 miles on it
