Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 09-30-2007, 07:47 PM
inatalonIXLR8 inatalonIXLR8 is offline
Question What happens when you run lean ?
Will running lean just blow holes in pistons, or will there be other damage done ? I'm looking at a GST that has been modded with a SAFC 2. There is a possibility that the previous owner set it too lean.
95 Talon Tsi AWD 5spd
2.4L4G64 6bolt JE8.5EagleTorqueplatedFully ballanced-balanceshaftARP Ferrea1mm 1Ghead ported/polished HKS264/272 fidanzagears turbonetics copy polished GT3076R VbandTial38mm cometic prothane mounts SARD850 stage4 Compclutch+flywheel 3"exh Walbro255 rewired Innovate wideband O2 ForgeBOV Autronic standalone innovative wideband[url=http://img494.imageshack.us/my.php?image=talonandhelicopter5as.jpg]
Old 09-30-2007, 09:08 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: What happens when you run lean ?
Burned up rings, melted pistons, scoring of the cylinder walls, warpage of and also I think that can cause pitting of the head. Besides that though, if they were careless enough to run it that lean, what else did the forget about/do to it thats not good? I wouldnt advise getting that unless you are getting a hella good deal.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 09-30-2007, 09:38 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Lean=detonation=blown motor
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 09-30-2007, 09:52 PM
So first thing to go would be pistons ?
Old 09-30-2007, 09:56 PM
Holset powered 420a
Yea, well the rings will probably be the first thing to go.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 09-30-2007, 11:54 PM
So doing a leak down test should show any damage ? And what pressure should a 6 bolt have on a compression test ?
Old 10-01-2007, 10:01 AM
Thor06's Avatar
Jizzed In My Pants
Yeah, a leakdown test should show you whats up. Compression from 6 bolts when they are new is supposedly like 160, most of them I have seen have been like 130-145.
Old 10-01-2007, 12:16 PM
Perfect timing Thor. I'm just heading out the door to do some tests on her now ! Thanks.
Old 10-07-2007, 05:49 AM
kjewer1 kjewer1 is offline
AF - Advisor
In most cases, speaking from personal experience, the sparkplugs ate it first, and then destroyed the head and turbo. In every single failure I had the corners of the pistons were knock off. There are pics on my site in the AFR/Blown motors section of the Tech Pages to explain this better. Compression was typically around 50-90 psi in these cylinders, for reference.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
