Old 09-30-2007, 07:41 PM
Megs1082 Megs1082 is offline
Turn Signal Problems - 1993 Jimmy
Nevermind
Old 09-30-2007, 07:58 PM
old_master's Avatar
Advisor/Moderator
Re: Turn Signal Problems - 1993 Jimmy
Check the right front T/S bulb, if it's ok, most likely the flasher unit needs replacement. A quick way to check bulbs is turn on the parking lights and the 4 way flashers, then watch the bulbs, easy to spot a bad one that way.
Old 10-01-2007, 08:52 PM
old_master's Avatar
Advisor/Moderator
Problem discovered??? What was the solution?
