Old 09-30-2007, 05:05 PM
slostealth96 slostealth96 is offline
I need help bad, please read...
I dont know what to do, ive been without a car having mommy and daddy drive me everywhere for 7 months. My 1996 Stealth ES was running great until the day before summer, it was the best summer i ever had, first my tranny went out, then my engine stopped running. I replaced my head gaskets, thermostat, fuel pump, battery, and a few other things. After all that it ran pretty crappy for a day then wouldnt start. I took it to a shop and they said overdrive went out and a piston is knocking so they adjusted the idle so it runs but not for long. What would the cheapest route to fix it? a cheap SOHC motor and tranny swap? or a piston kit and have a shop fix it? they said my tranny might be electrical becuase it revs really high when i get to about 40 MPH, then is slips into gear and keeps going, but its blowing smoke from the exhaust. That was all about 3 months ago and its still running and drives but i don't trust to take it anywhere but around the block once a week to keep it running... What should i do? any suggestions?
Old 09-30-2007, 06:36 PM
new2mitsu new2mitsu is offline
Re: I need help bad, please read...
honestly, it would probably be jus as cost effective to buy a JDM motor, as it would be to rebuild, especially to have a shop work on it.... i don't know what your budget is, but you could get a DOHC Tranny, ecu, and Engine for around 800 bucks, which would be great because that is a hell of a step up over the SOHC... but, you still gotta swap it, or pay someone to do it. But, what i would do, if you gotta lil cash, is take it as an oppurtunity for a TT swap... you can get a VR4 5 speed tranny, ECU and Engine, as a package for about 2500 shipped, which isn't really that outregeous... jus my 2 cents...
'93 3000gt VR-4
170k, 27k on JDM motor
MBC @ 14.5 psi
Datalogger
Intake
T-Pros Downpipe
Gutted Pre Cats
Mods to come: Upgraded Fuel System and 75 shot of Nitrous, Full Exhaust and hopefully 15Gs
Audio
Sony Deck
Eclipse 6x8 2 ways in the back
Clarion Kevlar cone Component System in the front
2 Alpine Type S 10 inch DVc Subs
1 Audiobahn 10 inch DVC D Jones Series
One 800 Watt Jensen amp
and a soundstream 300 watt 4 ch to the speakers
And still under 4000 lbs w/ me in the car
Old 09-30-2007, 08:16 PM
ya i was thinking about that, i have about..2500 bucks for a budget too, but would i have to do any modding? would it just drop in? since mince is a 96 would the first gen TT motor and 5-speed go in since my gen was the 6-speed? Im more of a muscle car guy so i dont know everything
Old 10-01-2007, 10:02 AM
jason_bet's Avatar
jason_bet jason_bet is offline
Send a message via MSN to jason_bet
yup.. there is some modding.. you can look at stealth316.com there is some good info on there showing how to convert JDM motors to fit US standerds.. you also can look on there how to wire in the CAS..
Jason
Old 10-01-2007, 01:41 PM
mistermoonpie mistermoonpie is offline
sounds like quite a predicament. TT swap sounds like the best way to go. However, new2mitsu said the package would be around 2500, which IS your budget. Would you have enough to have someone put it in or do you wanna do the whole TT swap yourself
Old 10-01-2007, 04:06 PM
actually i dont, but since my car is an automatic, would i have to do alot to swap the engine/tranny with a DOHC/5-speed? I hope i would have a little left over, and i dont think i could do it myself i would have a shop do it. But im sure they would charge a ton. How much work do u think i would have to do to do an auto to a manual swap? and about how much would that cost?
Old 10-01-2007, 04:54 PM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
sounds like you might need to just stick with getting a $800 engine
unless you wanna save up more for you tt swap
Old 10-01-2007, 05:52 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
A DOHC swap on a SOHC is huge pita. Theres alot of extra work required and its not a simple drop in. Find yourself a lower mileage SOHC engine and drop it in. I blew mine last year and basically had an engine given to me. Had 80k on the clock. Deals are there to be found.
Old 10-01-2007, 06:12 PM
liquidPunk's Avatar
liquidPunk liquidPunk is offline
Send a message via AIM to liquidPunk
I concur with stealthee, replace the soch, get chicks with the look of said vehicle, then if you want speed save up for a vr4. otherwise i think you will be hurting for money.
1992 Mitsu 3000gt sl 5sp
- High flow filter - Pioneer head, dual 10's - H4 headlight conversion
- Throttle Body Spacer - The "For God's sake stop that infernal buzzing" mod
- LED "Snake Eyes" - Lightweight Crank Pulley
-More to come-
Your 3000GT is the 5095th out of 6964 . Only 41exactly identical
Bloody Knuckles from Changing Fuel Filter Crew Member #1
Old 10-01-2007, 11:26 PM
as far as the cost of the swap... for SOHC to SOHC with tranny already attached to the engine it calls for 13-14 hours of labor... and if you go to a shop that dosent kno jack bout 3s cars, they'll prolly take 20 hrs+ to do it...
but assuming you go to a shop that is 65 bux an hour, and it only takes 13 hrs, thats bout 845 dollars... for labor alone, but if you do go SOHc to SOHC, you'll not need too many parts, id say you can go SOHC to SOHC for about $1000 plus the cost of the engine... then you could use the rest of the cash for new exhaust and a 100 shot, and still have about 500 bux left over if you play your cards right, that's what i'd do...
'93 3000gt VR-4
MBC @ 14.5 psi
Datalogger
Intake
T-Pros Downpipe
Gutted Pre Cats
Audio
Sony Deck
Old 10-01-2007, 11:34 PM
sounds like a plan to me. Can an SOHC engine take a 100 shot of nitrous safely? I dont know much about nos but it seems like a bit much for the SOHC
Old 10-02-2007, 12:56 AM
jason_bet's Avatar
I would think so.. I would honestly feel good about doing it.. but I am not tight with money and know how to work on 3k's so the risk for me is minamal..
Jason
Old 10-02-2007, 09:13 AM
aaah theres the difference. IF i were to ever work up enough money to put NOS on my car, I wouldnt have enough to take care of any damage. So I'm a little stingier on what I do to my car. But once I graduate college and Med school and become a surgeon...Im gonna be blowin money left and right on cars lol
'97 3000GT SL
-Short Ram Intake
-Test Pipe
-Custom Exhaust
-17" Infinity Rims
-Infinity Kappa Component Sound System
-Kenwood Double Din Headunit
Old 10-02-2007, 09:26 AM
jason_bet's Avatar
good luck with that.. hopefuly it works out for you
Jason
Old 10-02-2007, 03:54 PM
i'd say you could take a 100 shot no problem, but if you wanna be safe, i zex kid comes with a 50shot nozzle, 75 shot nozzle and a 100 if i'm not mistaken... plus i think it has an auto shutoff saftey switch for fuel cut if you hook it up right...
'93 3000gt VR-4
MBC @ 14.5 psi
Datalogger
Intake
T-Pros Downpipe
Gutted Pre Cats
Audio
Sony Deck
