Go Back   Automotive Forums Car Chat > Chrysler > Lebaron
Old 09-30-2007, 04:30 PM
mema mema is offline
Unhappy leaking transmission
have '95 LeBaron-transmission pan leaking around 1 bolt-changed gasket & filter 2x. Once with rubber gasket then with cork. Used different sealer both times. Still leaks at same bolt. Help! Thanks!
Old 10-04-2007, 11:32 AM
95_dodge_avenger 95_dodge_avenger is offline
Re: leaking transmission
i have another trans im wantin to get rid of, its been rebuilt
Old 10-04-2007, 12:11 PM
flyguy123 flyguy123 is offline
Remove the pan and look at where it is leaking. Its probably beveled up where the bolt passes through. Simple fix, take a hammer and flatten it back into shape. Or another theory is that the bolt is bottemed out, just add a washer and it should be fine.
