Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 09-30-2007, 04:19 PM
turbosivtec turbosivtec is offline
engine/tranny problem
I got a 95 neon and I just change out the tranny to a different one from a 96. the problem is when I start the car the mph rev high to like 30-40 mph and when I put to Park or neutral. It goes to zero. so what is the problem if anybody know?? Am I missing a plug or is the tranny good or not??. thanks
Old 10-01-2007, 11:26 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: engine/tranny problem
TPS or IAC motor.
2003 Dodge SRT-4
Old 10-04-2007, 07:59 PM
Originally Posted by das2123
TPS or IAC motor.
my tps and iac seem to be intact.. and i still getting the high revin. is it anything got to do with my transmission or is it one of my sensor?
Old 10-04-2007, 08:25 PM
does my speed sensor got something to do with it??
Old 10-05-2007, 10:14 AM
denisond3 denisond3 is offline
We need more info. Can you put the car in gear and drive it around? When you say the revs go to 30-40 mph, do you mean the engine revs that high,? or the speedometer reads that high,? or is the car going at that speed? And will the engine idle normally when the tranny is in Drive?
I dont know if the speed sensor would cause this or not. You might want to check whether its connectors is fully seated. Its not easy to see or reach unfortunately.
