Old 09-30-2007, 02:14 PM
docddt docddt is offline
98 mercury mystique
Hi
I lost a key to my mystique...which is a chip key and trying to figure out the cheapest way to replace it??
If i have only one key now can I somehow program the new key myself or can i somehow use a non chip key? Is there a way to disable the chip reader??
Help
Old 09-30-2007, 02:57 PM
rjeffery rjeffery is offline
Re: 98 mercury mystique
Sounds like a good question for the Mercury Mystique forum...
http://www.automotiveforums.com/vbul...lay.php?f=1120
2002 1500 Ext. Cab 4.8L 2wd.
K&N FIPK, Cat Back Exhaust, Rancho RSX Shocks, Silverstar Headlights High & Low, Infinity Reference Door Speakers & 10" Dual Voice Coil Sub. 265/75/16 BFG AT/KO's, Spray-In Bed Liner, Hella FF75 Fog Lights, Hella FF75 Driving Lights.
Old 09-30-2007, 02:59 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Originally Posted by docddt
Hi
Help
The Mercury Mystique is my favorite sub-model of the Silverado.
You really should post in the correct forum, but since I know the answer, here it is:
You can't program the new key yourself. If you want to use a non-chip key (assuming the same type of key: length, side dealeys, etc) you will need to get a wiring diagram for your car and "lie" to the computer inputs so it thinks that the key is always in the cylinder. Depending on your mechanical inclination and the avalability of wiring diagrams, you may be better off just paying for the new key.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 09-30-2007, 05:11 PM
bigbadram51 bigbadram51 is offline
2004 Silverado Half-Ton Crew
7-9" Cognito Lift (set at 8" right now) Betts 7" rear springs w/factory block
3" PA Body Lift
Yukon 4.88's with Auburn LSD
Xentec 6500k HID lows, Silverstar Ultra brights
Wade in channel window vents
Covermaster Top
Flowmaster 40 series, dual outs
Nelson 89/91 HOT TUNE
20" MB Gunner 6's, 37" Toyo Open Country MT's
Eclipse AVN6600 w/sirius and IPOD controllers
Code Alarm w/ Remote Start
