Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 09-30-2007, 12:16 PM
fiftyplus fiftyplus is offline
2000 Chevy Malibu
Need to know how to remove front door panels without damaging so I can put in new speakers
Old 09-30-2007, 07:26 PM
moon03 moon03 is offline
Re: 2000 Chevy Malibu
Chiltons has the directions basic way is remove the cover for the mirrors (upper foreward) pry the switches out and disconnect, - door latch has one screw (torx head) the door pull has a cover with two screws behind it (7mm) then its just pry the panel off carefully I use a sctew driver and get close to the chips I start at the bottom as the panel top has a channel that has to lift up to clear. best bet is get a Chiltons mine is in the car.
the switches on the passenger door I have taken off the drivers door may have screws holdinh the window switch and you pry the plastic off of it first.
, again I havent done that door. the clips are a lot better than the ones in the older cars and putting the panel back is easy and its held as good as before you started.
