Go Back   Automotive Forums Car Chat > Ford > Contour
Old 09-29-2007, 09:22 PM
veedubn veedubn is offline
97 contour engine electrical problem
iv been trying to figure this out for monthes. the car isnt charging or something.
i'v replaced the altinator and the battery and checked all the fuses and the mega fuse and the car still isnt charging.
i'v tried disconnecting the battery while its runing and it died right away. the was to check if the car will run off the altinator.
so any help would be very greatful. -thank you
Old 09-30-2007, 11:20 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Re: 97 contour engine electrical problem
Your reasoning is backwards here. A car cannot run off the alternator alone. A car can however run off the battery, until the battery dies. Thats why theres an alternator. To keep restoring power to the battery. The car dieing when you disconnected the battery is exactly what it should do in any sort of circumstances.
Are you sure the alternator is working? If so, what have you done to test it?
Are you sure you checked the correct megafuse? If you have the V6, its on the rear valve cover. Its NOT in the fuse box underneath the hood.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 10-01-2007, 09:20 PM
i had the altinator tested. then i put a new battery in and drove it a few days and then the battery died?
Old 10-01-2007, 09:53 PM
and the megafuse i referenced above?
"The CEG Nazi"
www.contour.org
Old 10-02-2007, 12:03 PM
thats the one by the firewall right? if so thats good; checked it with a multimeter.
