Old 09-29-2007, 09:16 PM
shadow120 shadow120 is offline
trans Q.
i droped the pan today and there is metal on the magnet most of it is past like but there was a couple of vary small pices to is this bad its a 93 dodge caravan 185k i think this is the first time the pan has been droped any input would be great thanks for the help
http://i212.photobucket.com/albums/c...Picture003.jpg
http://i212.photobucket.com/albums/c...Picture002.jpg
http://i212.photobucket.com/albums/c...Picture001.jpg
Old 10-04-2007, 11:39 AM
doratheexplorer's Avatar
doratheexplorer doratheexplorer is offline
Re: trans Q.
Originally Posted by shadow120
i droped the pan today and there is metal on the magnet most of it is past like but there was a couple of vary small pices to is this bad its a 93 dodge caravan 185k i think this is the first time the pan has been droped any input would be great thanks for the help[/url]
This looks pretty nasty! The fluid looks toasted and the magnet looks like the bunghole of an Australian Sheppard! Purchase two or three tranny filters, 10 quarts of ATF-4, a tube of high-temp sealant, and begin a mild flush procedure...replace with clean fluid/filter...drain after 1K miles...replace with clean fluid/filter...drain after 1K miles...replace with clean fluid/filter...etc., until the 10 quarts is spent.
Old 10-13-2007, 12:54 PM
michfixit michfixit is offline
Re: trans Q.
Yes, he should def change trans fluid. But it is cheaper to use the tranny line (after you drop pan & fill w/ new fluid) since you don't have to keep drain/fill the van all the time. This method will get the old out of the rest of the trans. However, I know the routine, but which line is the return line to the transmission? And, has anybody done this on the caravan b4? I want to do it, but need to locate the proper line.
Any help?
