Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 09-29-2007, 03:32 PM
ewidder ewidder is offline
Accord EX Transmission - Strange Condition
I have a 90 Accord EX that has had a peculiar transmission behavior for the past year (first occurred on frigid day). The transmission generally losses Drive (& REV) eventually. It is always OK at startup, but within 10-15 mins of operation, will begin to slip or have delayed/extended shifts. Normally, I would just say that the transmission is spent after 200 kmi, and get it rebuilt. This is of course what any transmission shop would recommend, since they make their $$ rebuilding transmissions (duh), but this problem can be temporarily overcome by simply re-cycling the ignition or giving the vehicle a short 0.5-1 min. rest. Then the condition will re-appear 5-10 mins later. This condition seems apparently electrical, rather than hydro-mechanical (i.e. rebuild). I have replaced the TCM with a rebuilt module, with no effect on the conditon. Fluid has also been checked and is OK. Good example of a system that 'almost fails' but doesn't leave you stranded, if you live with the odd periodic ignition reset trick. Is this some solenoid or other electrically diagnosable condition? I would be greatful for any suggestions on this perplexing situation. Thx - Ed
Old 10-05-2007, 07:58 AM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: Accord EX Transmission - Strange Condition
It does indeed sound like a sensor of some sort... probably a pressure sensor... while your at it, change the tranny fluid.
