View Poll Results: S-10 Charging problems
NEED HELP 0 0%
Electrical Diagnostic 2 100.00%
Multiple Choice Poll. Voters: 2. You may not vote on this poll
Old 09-29-2007, 03:23 PM
Chevypride247 Chevypride247 is offline
Out Of My Mind
I have a 1991 Chevy S-10 Durango 4.3ltr that has me stumped.
I am having an electrical prob replaced the plugwires, altenator, and battery truck only starts when jumped at high idle. then after started says its charging the battery and shows it on a volt meter but after you shut it off it wont start again cleaned all connections to battery and grounds but still no avail
in the beginning it would always dip into red zone (battery meter) while accelorating but would level out still does it but now it either dies while idleing or when shut off no restart. No clicking from starter just buzzing from ignition alarm
Old 09-29-2007, 03:36 PM
silverblazer silverblazer is offline
Re: Out Of My Mind
First off Durango is made by Dodge. Lets get the straight!!!!! Sounds like you got a serious draw on the battery. Try charging your battery then hook your positive wire up. Then use a circuit tester between your neg lead and post. See how bright the light shines. make sure you have everything turned off. Check all of your ignition wires for bad spots and run through all fuses. Make sure the battery is charged with a low amp and give it time to charge. Then you need to load test it.
1995 Chevrolet Blazer LT
4x4 Red and Silver
CHEVYS RULE
Old 09-29-2007, 03:49 PM
blazee's Avatar
blazee blazee is offline
Problem?
Re: Out Of My Mind
Just to "get it straight" Durango was a trim package for Chevy long before Dodge made the Durango suv.......
