Old 11-26-2002, 06:52 PM
Ryan328i Ryan328i is offline
Question IDMAX's, let's here all your opinions on them
Alright here the deal, i don;t own a honda/acura but most of my friends do and i figured id get the most response in here. i've been looking into subs. i want really good sq and some pretty good spl too. im leaning towards Image Dynamics IDMAX12. So lets here your opinions on them. Also if any of you have them, what are you using to run them? Im planning on just having one i think 2 is a little over kill. One more thing, dual 2 ohm or dual 4 ohm? Thanks a lot.
Old 11-26-2002, 08:08 PM
strodda strodda is offline
sorry i cant be of any real help, since i dont have them. but if you only want one sub, i'd get the 2ohm dvc. that way you can get a monoblock and take advantage of the 1ohm output(if capable).
Old 11-26-2002, 09:34 PM
delsolsi delsolsi is offline
Or you could run the voice coils in series to get a 4 ohm load if your amp is only 4 ohm stable when brigded.
Old 11-26-2002, 11:51 PM
GSteg's Avatar
GSteg GSteg is offline
Send a message via AIM to GSteg
or get dual 4, wire them in parallel, and then find an amp that makes the most power at 2ohm anyways..
i say get an adire audio brahma. in a proper install, the brahma should the the IDMAX's crown in SPL and SQ. very good subs (did i mention crazy excursions? ) also the Elemental Design SP-series (15") are nice.
I love them sub wufers
Old 11-27-2002, 08:11 AM
I found a good deal on a dual 2 ohm so thats what ill prolly be going with. thanks for the info tho. Now isn't the brahma more spl than sq? Im not a real; fan of 15's because of the deep low bass sound. I like more of a hit hard in your chest sub. Any one else have any experiences with Image Dynamics?
Old 11-28-2002, 12:53 AM
GSteg's Avatar
the Brahma is SQ sub. adire audio built the sub with SQ in mind, but with it's design, it can get very loud. just think of it has a bonus. these subs will hit, possibly harder than the IDMAX. any subs will hit hard if you put them in the right box.
Old 11-28-2002, 08:56 AM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
SQ and SPL are not mutually exclusive ........ many of things that make a sub good at one, are also necessary for the other. The real determining factor for SQ vs SPL is design of the box.
Old 11-28-2002, 11:45 AM
do angles matter in the design of a box? or is it just the volume inside?
Old 11-28-2002, 12:53 PM
If theres enough space and the shape is right, I try to use the golden ratio when designing the box after I figure out what volume I want. I don't know how much of a difference it makes, but I've been really happy with the results when I've done this.
