Old 09-28-2007, 05:34 PM
taz16353 taz16353 is offline
'96 escort 1.9 auto trans. Torque converter locked ?
On my escort when i put in drive it instantly stalles when reve up and put in gear will move a bit but not very good if jack up and hang front in air wheeels spin fine and not stal when put in gear ones say torque converter is locked and unplug wires i unplugged wires on front of transmission but no change so i like know more what could be wrong.
Old 09-28-2007, 08:08 PM
mightymoose_22's Avatar
mightymoose_22 mightymoose_22 is offline
Re: '96 escort 1.9 auto trans. Torque converter locked ?
It sounds like your engine just isn't handling load. It might stall in neutral if you just turn the AC on.
Check to make sure that are 4 cylinders are getting spark.... maybe do a compression check too. I bet your engine is not running on all 4 or is not at full power for one reason or another.
Old 09-28-2007, 10:09 PM
Davescort97 Davescort97 is offline
Escort guy
Idle speed could be incorrect. Check IAC valve. Fuel filter could be clogged. Spark plug wires could be bad. You could have a vacuum leak on the intake manifold.
Old 10-05-2007, 10:47 PM
bblanchard bblanchard is offline
yea i would check basics like plugs, wires, compression alot of times bad wires can seem like a bad converter
Old 10-05-2007, 11:09 PM
denisond3 denisond3 is offline
Mine is a 92. Do the 96's still have the big rubber air inlet duct running from the air-filter/mass-air-flow-sensor up to the throttle body? If there is any crack in that rubber duct, it will really mess up the air-fuel mixture, and result in feeble engine power at low rpm.
