Go Back   Automotive Forums Car Chat > Mitsubishi > Lancer
Old 09-28-2007, 04:43 PM
prosportsdude33 prosportsdude33 is offline
How do I install new radio?
I need to take out the stock deck and put a new one in....how do i take it out?
Old 09-30-2007, 02:42 PM
1992eclipseGS 1992eclipseGS is offline
Re: How do I install new radio?
you probably should buy a haynes manual.. it should tell you what you need to do.
1998 RS
5 speed, Stock front bumper w/molded urethane lip, Blitz side skirts, Bomex rear, JSP Carbon Fiber hood. Halo Projection Headlights, Escort radar detector, Turbo style spoiler, 1,200 watt sound system with 2 dual 12 subs, 20% executive tint, 17" sport rims, Custom built 2 1/2 Exhaust, OBX 4-1 Header, CAI, KYB GR-2 struts, Sprint lowering springs.
Old 11-17-2007, 10:59 PM
I figured it out. You have to pull of the A/C knobs with pliers and unscrew the screws behind the knobs. Then you have to take a screw driver or something like that and pry it along the outside of the panel around the radio. Wrap it with tape so that it wont scratch the panel. Slowly work your way around the panel so that you can loosen all the clamps holding on. When you get to the last few, it should pop right off and you can then unscrew the radio and take it out. When you install the new radio, either buy a wireing harness or hardwire it straigh in. But hardwireing it, as i found out might void the warranty of the radio if you have one or w/e.
