Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-28-2007, 03:46 PM
1992eclipseGS 1992eclipseGS is offline
Please Help!!! Turning signal doesn't work!
I had my car jump started last night after about a week of not running it.. well everythang seemed fine for a lil while, then all of a sudden I noticed my turning single was not working..So when i got home I check the fuse inside the car and sure enough it was blown.. So i changed it this afternoon and the turning signals still doesn't work? Anyone have any ideas???
1998 RS
5 speed, Stock front bumper w/molded urethane lip, Blitz side skirts, Bomex rear, JSP Carbon Fiber hood. Halo Projection Headlights, Escort radar detector, Turbo style spoiler, 1,200 watt sound system with 2 dual 12 subs, 20% executive tint, 17" sport rims, Custom built 2 1/2 Exhaust, OBX 4-1 Header, CAI, KYB GR-2 struts, Sprint lowering springs.
Old 09-28-2007, 04:19 PM
nofear39427 nofear39427 is offline
Send a message via Yahoo to nofear39427
Re: Please Help!!! Turning signal doesn't work!
Check the bulbs too that may be your prob.
Old 09-28-2007, 06:51 PM
TalonEclipseMixGsx's Avatar
TalonEclipseMixGsx TalonEclipseMixGsx is offline
Did you check your fuse a second time? It could have a short and keep blowing each time you cut on the turn signal. Could be a flasher as well. Do your 4-ways work?
98 Eclipse GSX-EVO3 16G, BC 272's,ETS FMIC and short route piping,TRE Stage 2 tranny, ACT 2100, Walbro 190lph,550cc jectors,SAFC NEO,GM MAFT, AEM UEGO wideband,ported SBR Exhaust Manifold,O2 Dump,EBay Intake,3" megan downpipe and catback exhaust,TurboXS boost controller,HKS BOV,Ebay Short Shifter,Boost Gauge,Symbroski shift kit & shift cable bushings, RRE catch can
94 Talon 1.8L-SOLD
02 Civic EX- Daily driver (staying stock)
Old 09-29-2007, 06:59 AM
4 ways as in hazard lights?? Yes they work!.. and My bulbs work. And I did check the fuse a second, third, and fourth time. Its not blown
1998 RS
Old 09-29-2007, 12:04 PM
Well if everything else is good, then it sounds like a turn signal flasher to me. Try replacing that.
94 Talon 1.8L-SOLD
Old 09-29-2007, 12:48 PM
okay i'ma check it out.. thanks!
1998 RS
Old 10-03-2007, 02:01 PM
Walleye catcher Walleye catcher is offline
IF this car was ever a tow behind vehicle they would hav installed a small diod on the wire going to the light, if its there just remove it.look for it next to light.
Old 10-03-2007, 02:29 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
.........wtf?
I highly doubt anyone would use it for a tow-behind vehicle, and I don't see how this has anything to do with is problem, because if it WAS a tow-behind, the people towing it would still need a way to use the turn signals without taking out the "diode" everytime they drive it.
95 Talon TSI AWD
97 Eclipse GST
