Go Back   Automotive Forums Car Chat > Chevrolet > Aveo
Old 09-28-2007, 10:17 AM
rober rober is offline
Braking question on 07 Aveo
Does anyone experience the car shakes when braking at freeway speeds (above 50mph)?
Old 10-17-2007, 07:09 AM
Melissayellowcar Melissayellowcar is offline
Angry Re: Braking question on 07 Aveo
I have a 2005 AVEO and I have had this problem on and off since day 1. It is really bad now.
Old 10-18-2007, 04:20 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Most likely warped front rotors. If the Aveo is the car I'm thinking of, the rotors are TINY. Braking produces heat, which can build up to the point where the surface actually starts to melt and bend. Going easy on the brakes will help reduce the heat. There could also be a brake proportioning problem that is causing the front to do more work than they're designed to do.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
