1997 Grand Voyager Cooling Fans
The cooling fans are not working on the van and I have checked the temprature sensor, anyone know where the fan relay is located on the vehicle?
Re: 1997 Grand Voyager Cooling Fans
To the drivers side of the radiator on the frame next to it or on the back side of the bumper frame in the same area. May need to remove the air intake ducting. Follow the wires from the fans. It's about an inch square and flat. Here's a picture:
http://files.automotiveforums.com/ga...cat=998&page=1
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds. **Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual. 07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan |
Thank you very much for your help and effort in this matter.
Replacing the fan relay solved this problem and the location was correct. All fans are operating and everything is running fine. Thanks so much for help on the location of this relay.
Glad to hear you're on the road again. Thanks comming back with the fix. I just wish they could all be this cut and dried.
This post also led me to the fix i needed. great place for information
Well let me tell you the symptom of what lead me to the fan relay. I turned the van off and when I did the fans kept running. I didn't think anything of it at the time as I thought the engine was cooling down. An hour later I came out and they were still running. I disconnected the battery and hooked it back up and they finally stopped running and when I say they finally stopped running, it was for good. The relay solved this issue so if your fans keep running after you turn your vehicle off, oh oh, fan realy is going.
Take care all! |
