Old 09-28-2007, 05:20 AM
windstarharv windstarharv is offline
ABS sensor
I have a 98 Ford Windstar. I exchanged a right side spindle with one I picked up from the junk yard. Now I have my ABS light on and the Trac Off light flashing. Can the ABS sensor be removed from the spindle and replaced with the one in the spindle I took off? How do I remove it if so?
Old 09-28-2007, 12:52 PM
catvents catvents is offline
Re: ABS sensor
It is usualy not easy to remove (without damaged it) because the sensor is often sticked by the rust. Try to soak it with PB Blaster (or similar) and be patient, you will probably have to do it a few time. Remove the small bolt and don't try to use any tool to pry it out because you will damage it.
Good luck.
Old 09-28-2007, 04:04 PM
phil-l phil-l is offline
Re: ABS sensor
I have removed ABS sensors on my Windstar - and discovered that it wasn't terribly difficult. The key is to be gentle and go slow. The portions of the sensor that actually touch the spindle are plastic, so it will eventually slide out. I can second the recommendation for PB Blaster.
2000 Windstar LX 3.8
1995 Contour GL 2.5
1986 Mustang GT 5.0 --> Sold, but missed on sunny days
