Old 09-27-2007, 08:49 PM
Arbalest's Avatar
Arbalest Arbalest is offline
Send a message via AIM to Arbalest Send a message via MSN to Arbalest Send a message via Yahoo to Arbalest
A/T lag...
I've, unfortunately, got A/T. Occasionally, it'll rev a little, then it'll uncomfortably bump into gear a second later, much like the effect you get when you haven't let the clutch out all the way in M/T when taking off. I've checked my ATF level, and it's fine, but I don't really know how to check and see if it's clean or needs to be replaced (I'm used to driving M/T, man do I miss it now). Anyone know what might be causing this?
Old 09-27-2007, 09:03 PM
VR43000GT's Avatar
VR43000GT VR43000GT is offline
Send a message via AIM to VR43000GT
Re: A/T lag...
Could be multiple things. Could be that something is broken inside the trasmission and is clogging the filter. IDK if there is a possibility that the TCU could be causing it? I would take it to a mechanic for diagnosis unless you really know automatic transmissions.....which I don't.
Old 09-27-2007, 11:29 PM
new2mitsu new2mitsu is offline
Re: A/T lag...
yeah, +1 on the filter, seems like fluid isn't circulating properly
'93 3000gt VR-4
170k, 27k on JDM motor
MBC @ 14.5 psi
Datalogger
Intake
T-Pros Downpipe
Gutted Pre Cats
Mods to come: Upgraded Fuel System and 75 shot of Nitrous, Full Exhaust and hopefully 15Gs
Audio
Sony Deck
Eclipse 6x8 2 ways in the back
Clarion Kevlar cone Component System in the front
2 Alpine Type S 10 inch DVc Subs
1 Audiobahn 10 inch DVC D Jones Series
One 800 Watt Jensen amp
and a soundstream 300 watt 4 ch to the speakers
And still under 4000 lbs w/ me in the car
Old 09-28-2007, 03:06 AM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
Re: A/T lag...
Worst case:
It's probably just old, the clutch discs inside are wearing out and not grabbing like they should (C1 clutch pack to be exact), or the pump isn't pumping hard enough to clamp down the clutch discs like it should (or filter clogged).
AKA
Your tranny is probably on its way out. Baby it and it might last a while. Swapping out the filter and fluid could either speed up or slow down the process of it dying, depending on how regularly the fluid has been changed in the past.
1997 Mitsubishi 3000GT VR4 - 269AWHP/290AWTQ (Mustang Dyno) - [email protected] - 1.756 60ft. - [email protected] (Best TDO4-9B Time) - Driver Mod - IPS TD04-19TL - SPEC 4+ - Wiseco Pistons - 3SX Custom Forged Rods - PMP FMIC + Much More.
Old 09-28-2007, 01:13 PM
Arbalest's Avatar
Re: A/T lag...
I'll keep babying it, but I've always heard about transmission failure as time progresses... I don't believe that the previous owners took very good care of it; it appears that they raced it (despite the A/T?), yet, I noticed Wal-Mart oil-change stickers (which shows either laziness or inexperience, I'm thinking the latter), so, apparently, they didn't know how to change the oil on their own. It's safe to assume that the transmission fluid hasn't been changed for a while.
