Old 09-27-2007, 05:42 PM
jrpiecemind jrpiecemind is offline
missfire Code 300
Do you have to pull distributer to install cam sensor on 95 jimmy 4.3 W ( EDI )
Old 09-27-2007, 06:06 PM
old_master's Avatar
Advisor/Moderator
Re: missfire Code 300
P0300 is commonly set due to a secondary ignition problem such as plugs, wires, distributor cap, rotor, or ignition coil. Did you also get a DTC for camshaft position sensor? If so, what code did you get?
Old 09-29-2007, 08:43 PM
[quote=old_master]P0300 is commonly set due to a secondary ignition problem such as plugs, wires, distributor cap, rotor, or ignition coil. Did you also get a DTC for camshaft position sensor? If so, what code did you get?[/quo
te] got a PO300 after installing coil and cam sensor
