Old 09-27-2007, 05:34 PM
bingkewl bingkewl is offline
correct amp?
i want to hook up 2 12" rockford p1s814 into an alpine MRV-F305. the subs are 8ohms. i'm having trouble finding specs on the amp, but i believe the amp handles 4ohms, so if i bridge the subs i should be fine?
does anyone have spec on this amp?
could i hook up my speakers (alpine SPR-57C) into the amp also? it is 4channel.
is the amp 400watts per channel or all the channels bridged?
Thanks.
T.Carter
Old 09-27-2007, 07:17 PM
bjboertje's Avatar
bjboertje bjboertje is offline
Re: correct amp?
you could bridge the rear channels of the amp and run the subs wired in parallel. then run the front channels to your SPR-57Cs. that would only give the subs 60 watts rms each though. your amp is 50 rms X4 into 4 ohms. 120 rms bridged X2 into 4 ohms.
2001 Ford ZX-2
Alpine CDA-9855
SAX 100.4
Rainbow CMX 265 front stage
Stock 5X7 rear fill
Hifonics BX1505D
TC-5200
Old 09-27-2007, 10:39 PM
Re: correct amp?
so if i wanted to pump the full 300watts into the subs, i should bridge it x2, and get a seperate amp for the speakers.
ty
Old 09-28-2007, 05:44 AM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: correct amp?
all regular car amps are rated at 4 ohms, and the class D one are rated at like 1 or 2 ohms. Why are your subs ratd for 8 ohms ?
Old 09-28-2007, 03:32 PM
Re: correct amp?
#1: the guys at the sound shop suggested 8ohms
#2: i was under the empression that 8ohms is "standard" and anything else was unusual.
Old 09-28-2007, 03:43 PM
bjboertje's Avatar
Re: correct amp?
ty
no, you can't use your amp or your subs to their full potential together. if you bridged the amp, ch 1 and 2 to one sub, 3 and 4 to the other, the amp would only see an 8 ohm load per set. then you would only be pushing 80 watts or so per sub. you really need either a different amp or different subs. those don't work too well together.
if you want to keep the amp, get a pair of subs that can be wired to 4 ohms each.
if you want to keep the subs, get a two channel amp that pushes around 300rms into 4 ohms bridged.
2001 Ford ZX-2
Alpine CDA-9855
SAX 100.4
Stock 5X7 rear fill
Hifonics BX1505D
TC-5200
Old 09-28-2007, 04:46 PM
Re: correct amp?
****, that's not good.
Old 09-28-2007, 06:40 PM
Audio Guy
Re: correct amp?
8 ohms is the HOME standard ..... 4 ohms is the standard for car speakers. Sounds like you need a new stereo shop.
Old 09-29-2007, 03:51 PM
Re: correct amp?
ah, see that's it. my father was an electrition, and i do electrical stuff now and than, so to me, 8ohms is standard for everything.
the dudes at the sound shop suggested 8ohms, i have no idea why.
