Old 09-27-2007, 04:00 PM
burnchassis3 burnchassis3 is offline
99 4x4 help
99 vin w 4.3
when i try for auto 4wd or 4 hi it just flashes...when I stop it will go into 4 lo everytime.
I heard mention of a vacuum leak possiblle?
Can someone tell me where to check 1st?
or another possible cause?
It did this a couple times last year ,but always went into 4wd..but now it just seems to flash.
No "check engine" lights or "service 4wd" lights are on.
Thanks
Old 09-27-2007, 05:38 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 99 4x4 help
Originally Posted by burnchassis3
99 vin w 4.3
Thanks
236 or 233 transer case?
MT
Old 09-27-2007, 07:17 PM
Re: 99 4x4 help
Sorry MT
I am not sure how to tell?
let me know ,and I can let you know.
Thanks!
CS
Old 09-28-2007, 08:42 AM
MT-2500's Avatar
AF - Advisor
Re: 99 4x4 help
There is a tag on back of transfer case that tells what one it is or what does the shift buttons say?
if they have a 4W auto on one shift button it will be a 236.
A 236 can be tested and checked for codes with a transmission/engine capaable scanner.
A 233 you can pull codes by grounding pin 13 on diagnostic connector.
In how to section there is some info on the 233 transfer case.
http://www.automotiveforums.com/vbul...d.php?t=572914
MT
Old 09-28-2007, 03:52 PM
Re: 99 4x4 help
I have 4wd auto switch ,so it must be a 236.
now for the vacuum........I bet I have a leak,can you tell me which hose is a vacuum hose for the 4wd? or where I can locate this to start looking.
Thanks!
CS
Old 09-28-2007, 04:30 PM
MT-2500's Avatar
AF - Advisor
Re: 99 4x4 help
Thanks!
CS
Sorry I can not find a vacuum diagram for it.
You might check a factory repair manual.
If the shift button lights are flashing I would check for codes first.
On vacuum.
I would start at front actuator switch and see if it is getting good vacuum to it and threw it.
Is you front axel locking in?
Can you hear transfer case shift or is it going into 4W low ok?
MT
MT
Old 09-28-2007, 06:59 PM
Re: 99 4x4 help
Yes it drops right into 4wd low.clunking and all.....its in 4wd low too I hammered it ,and about ripped the wheels off.
CS
Old 09-28-2007, 07:06 PM
MT-2500's Avatar
AF - Advisor
Re: 99 4x4 help
If it goes into 4 W low the vacuum is working.
Get it on a transmission/transfer case scanner and run the scanner test and post back codes.
MT
