Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 09-27-2007, 03:00 PM
McLin's Avatar
McLin McLin is offline
Seatbelt problem...
Hi,
today i was on wet gras, and i was fixed with my car.
So i opened the door and make my head out of that, and i was forgotten that the belt come to front, and now i can hear the motor but the belt nothing do anymore.
I have an 90's T-Bird LX.
Can anybody help me, where i can look first to fixed it?
Or say me what happens?
Thx alot.
Best regards McLin.
My Lumina
My Girlfriends Lumina
Mileage:
Old 10-06-2007, 08:46 AM
97Bird's Avatar
97Bird 97Bird is offline
Re: Seatbelt problem...
It sounds like you stripped the gear on the motor. That is the first place I would look.
The Original 97Bird
Old 10-06-2007, 03:19 PM
McLin's Avatar
is it possible to get to the motor, without screw out the backseats?
And thx for the answer...
Best regards McLin.
My Lumina
Mileage:
Old 10-07-2007, 01:33 PM
97Bird's Avatar
The rear seat has two pieces, the top backrest and the bottom seat cushion. To remove the bottom seat cushion push the front of it towards the back of the car and then lift up on it to disengage it from the clamps. The backrest should be held in place with two bolts that can be seen once the bottom cushion is removed. After removeing the bolts, lift up on the backres to remove it. The screws in the plastic side panel will have to be removed and the panel pulled away to get to the motor and track.
The Original 97Bird
