Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 09-27-2007, 10:25 AM
IZ1111 IZ1111 is offline
Could this be a bad Alternator?
When in morning start-ups. My car seems to die down after seconds, unless I keep my foot on the accelerator to keep it from dying. And when it dies down I can see the battery needle on the gauge go crazy and then dead. After that the battery light turns on. But if I warm it up with some gas for a while it works fine, only on cold start-ups this problem occurs. Could this be a bad altornator starting to give up? Thanks for any responce.
Old 09-28-2007, 02:09 AM
reekor reekor is offline
Re: Could this be a bad Alternator?
Nah I don't think so, seems more like your rpm's are dropping too much and the alternator stops charging due to a lack of rpm.
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 09-28-2007, 07:49 AM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Check idle speed control motor. This is what makes it idle faster when cold.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 09-28-2007, 01:05 PM
where can I find that. And how can I fix a lack of rpm.
Old 09-28-2007, 01:42 PM
way2old's Avatar
TOKEN HILLBILLY
What year Vic is it?
Old 09-28-2007, 02:27 PM
92 Lx
Old 09-28-2007, 05:52 PM
way2old's Avatar
TOKEN HILLBILLY
It is located down behind the engine between the drivers side valve cover and the throttle body. You have to look down behind the engine to see it. it will look similar to, but not exactly like the one in the picture.
Old 09-28-2007, 07:58 PM
Oh, thats going to be hard. Ok, I'll take a look. Thanks.
Old 10-02-2007, 11:36 PM
biggbabysweetz1's Avatar
biggbabysweetz1 biggbabysweetz1 is offline
also check any and all electrical connections for corrosion, i had a 92LX that loved cooking the corrosion and messing my charging system up
Suck squeeze
Bang Blow
Old 11-21-2007, 08:03 AM
Well, I was looking at things around my engine and I think I found a loose connection. I have a picture below (its dirty under the hood I know). But from what I've read, this is the idle speed control (circled in green). and I looked at the connections and one was loose (circled in red). Does anyone know what this connection goes to. I've looked around behind the engine but couldn't find anywhere it could have gone in.
Old 11-21-2007, 12:08 PM
The black thing is a EGR regulator and the plastic hose plugs into the top of EGR valve (the round thing below the EGR regulator).
Old 11-21-2007, 04:58 PM
??? Ok. I thought I solved my problem.
But I'll see about the round thing below. Thanks.
Old 12-07-2007, 02:24 PM
Well, I got another hose that I just found lose. I tried to find the connection that it goes in the back of the engine somewhere, but I dont see anything or have a clue where it should go. Does anyone know? Thanks.
Old 12-07-2007, 05:42 PM
way2old's Avatar
TOKEN HILLBILLY
That hose goes down to the Idle Speed Control motor. Look down behind the engine directly under the hose below the wiper module and you will see where the hose plugs in. That could be your problem. It is tight down there. Good luck.
Old 12-07-2007, 10:22 PM
Wow, thanks. Found the linking hose tucked away out of sight. But once I put them together, I actualy got a little boost in performance. Plus I found the location of the speed idle control too. But...... after a while without feeding it some gas for a while, the engine still dies down. I maby thinking it could be a worn out fuel pump, becuase I can't get a reading on the fuel level either, so I may try replacing it and seeing how it improves.
Thankyou to all the replies. I really appreciate the sopport on this site.
