Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 09-27-2007, 10:15 AM
jharris26 jharris26 is offline
starting issues
went out to start my bravada this morning, and it just won't stay started. i can hear the fuel pump start, it turns over and acts like its gonna run like normal for 2-3 sec. then just cuts out. pumping gas doesn't do anything. sort of at a loss as to what is wrong. replaced the fuel filter 2 years ago. oil pressure is good (although desperately need to change the oil). full tank of gas, didn't use it at all yesterday. last driven was in a hard rain tuesday night.
thanks
josh
/edit
i changed the fuel filter and the fuel pump had plenty of pressure...
Old 09-27-2007, 05:49 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: starting issues
You're gonna need to put a gauge on your fuel injection, it's hard to judge 40psi(too low) against a normal 60psi.
A fuel injection pressure test kit is available at most auto parts stores and currently on sale at Harbor Freight.
Here's where you test it.
Old 09-28-2007, 08:14 AM
Re: starting issues
my wife brought to my attention that the security light has been on all last week. on research, that makes sense, cause it looks to start normally, then things just get "cut" off. so now i think its an issue with the passlock system. i've had suggestions to put the key in aux position for 10 min, but last night i did that and drained the battery, retrying after having jumpers on it. any different suggestions on how to reset the passlock system? or even disable it ?
thanks
josh
Old 09-28-2007, 05:43 PM
ericn1300's Avatar
ericn1300 ericn1300 is offline
AF Premium User
Re: starting issues
thanks
josh
could be the passkey vats system. check out this thread and see if it helps: http://www.automotiveforums.com/vbul...highlight=vats
Old 10-02-2007, 05:25 PM
glathrop glathrop is offline
Re: starting issues
had the same problem couple years back. After repeated trips to the
dealer and about 1200.00 It turned out to be the ign switch so try that first
Old 10-15-2007, 08:46 AM
Re: starting issues
forgot to respond with the solution. it was the passkey system. found out that to reset the system, just put the key in the on position without turning it all the way to on for 10 min. worked like a charm. thx again
Old 10-15-2007, 09:46 PM
AF - Advisor
Cool Re: starting issues
Thanks for the update Josh.
