| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
Need a little help, please
Hello, guys
I am sorry if it sounds stupid for you. But I am kinda lost. It's about that which injectors I should use?!?! I have got a 1G AWD, I run 16g Evo3 GT. I wanna go for DSMlink. According to the info I found here, the 650cc are good enough for me. But what if I go for 950cc , so I will have them in the future if I want to upgrade the turbo. Is there gonna be a problem running the 950cc with DsmLink on such a small turbo? Something else - is a Walbro 199 enough or I should go for Walbro 255+ FPR, or Walbro 255 lp w/out fpr?!?! If I get the 3"GM MAF , should I go for the translator as well, using DSMlink?!? Thank you in advance guys! |
Re: Need a little help, please
If you're sure you are going to get dsm link. Then get the 950s. If you are not going with dsm link and instead going the SAFC route, 650s are the biggest ones you'd want to get.
As far as I know you wouldn't have any problems with the 950's since you can compensate for injectors up into the 1000cc range. You might want to ask the dsm link guys. As far as the fuel pump if your staying with the 16g get the 190. If you have future plans just go for the 255. Of course it's the more preferred path to get the FPR, but that depends on if you care about fuel economy. I personally am going to try running with the 255 and no FPR, and Ill decide for myself weather I want one or not. Also with whatever fuel pump you get, its a good idea to rewire it. With the GM maf, I think you need the translator with it. But again I'm not sure how different it would be. You'd want to ask the DSM link guys about that.
98 Eclipse GSX-EVO3 16G, BC 272's,ETS FMIC and short route piping,TRE Stage 2 tranny, ACT 2100, Walbro 190lph,550cc jectors,SAFC NEO,GM MAFT, AEM UEGO wideband,ported SBR Exhaust Manifold,O2 Dump,EBay Intake,3" megan downpipe and catback exhaust,TurboXS boost controller,HKS BOV,Ebay Short Shifter,Boost Gauge,Symbroski shift kit & shift cable bushings, RRE catch can 94 Talon 1.8L-SOLD 02 Civic EX- Daily driver (staying stock) |
of course you still need the translator with a gm maf even with link. Link will do absolutely fine with 950's the general consensus on the link forums is that it gets tricky after 1150's. and talon is right about the rest.
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM. 18 Inch chrome rims In closet AEM Fuel Rail, SS Lines, 1997 TSI AWD Diamonds Are 4Ever 12.7 @ 107 http://i83.photobucket.com/albums/j2...y/DSC00461.jpg |
The AFPR Is not absolutely necessary witht he 255lph. But like TEMG said, you will get crappy gas mileage and you will definately be running rich, ,since the pressurized fuel from the fuel pump will simply overrun the stock FPR.
This also happens with the 190lph. It is just alot less noticeable.
1991 GSX 2.3 Stroker |
Thanks, guys!
I will go for the 255 + Fpr then for sure! Since I haven't got my Link yet, I wanted to know if I am gonna need any datalogger using DSMlink?!?!? I guess, not!? And I also found out that my ECU doesn't have the Eprom, so I am gonna need to get one. Do you know any good place I can order it from? Are they different for the FWD and AWD? Is a one from a Talon going to work? |
Eprom ECU's are all over the internet. Check ebay and dsmtrader
98 Eclipse GS Turbo Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio 1981 Chevy Scottsdale 1987 Nissan 300zx - Chump Car 2001 BMW 325i - DD |
Turbo ECU's are the same, and one from a Talon/Eclipse/Laser would work. Just make sure the ECU comes from the same generation of cars. Like you need a Eprom ECU from a 1G.
Also there is a difference between the 90-91 ECU and the 92-94 ECU. The tach lines are different so, while you can use one from the other, your tachometer may not work. (In which case you need to switch some pins around on the ECU connector)
Actually Wil, the 90 is the only oddball. If you have a 90, you will need a 90 ECU, otherwise any 91-94 should be fine. Also, auto vs manual doesnt matter. Also, DSMlink itself is one hell of a data logger, you will not need another.
Little reading on the subject: http://www.fullthrottletech.com/showthread.php?t=882
Thank you guys!
I've got the '91 model
i have 'link, 950's, and a E316G... and look at me! i'm happy as can be!
