Old 09-27-2007, 07:31 AM
bheston bheston is offline
350 very sluggish until engine warms up
1994 4x4 1500 with 350 engine, motor is very sluggish until it runs for 5 min or so and warms up, then runs great. Is the choke not working? Any suggestions on what to look for are appreciated.
Thanks!
Bob
Old 09-27-2007, 03:37 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: 350 very sluggish until engine warms up
Thanks!
Bob
No, the choke is not working. In fact, I think it fell off. Sorry, couldn't resist
Seriously though, I would first check the spray pattern from the fuel injectors. They could be more or less just driping gas in if they're dirty.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 09-28-2007, 06:55 AM
The spray pattern from the injectors appears to be fine. What else should I look at?
Old 10-02-2007, 07:46 PM
2000CAYukon 2000CAYukon is offline
Engine coolant temp sensor not working properly? Worn EGR valve or EGR solenoid? Vacuum leak?
//2000CAYukon
