Old 09-27-2007, 07:16 AM
jimmybag jimmybag is offline
03 silverado 5.3 engine knock??????
have 03 silverado with 5.3 engine, 60k on it, has a knock at cold start until warms up any ideas??
Old 09-27-2007, 09:09 AM
rjeffery rjeffery is offline
Re: 03 silverado 5.3 engine knock??????
It's normal and causes no harm to the engine. Some claim to eliminate/minimize it with different oils. If you want a little more reading, do a search for "piston slap".
2002 1500 Ext. Cab 4.8L 2wd.
K&N FIPK, Cat Back Exhaust, Rancho RSX Shocks, Silverstar Headlights High & Low, Infinity Reference Door Speakers & 10" Dual Voice Coil Sub. 265/75/16 BFG AT/KO's, Spray-In Bed Liner, Hella FF75 Fog Lights, Hella FF75 Driving Lights.
Old 09-27-2007, 03:09 PM
knogoodidleft knogoodidleft is offline
ha, there is actually a site for this http://www.pistonslap.com./ I am a synthetic advocate but maybe running some non synthetic will fill the bore, or heavier weight, eh, thinking about it, it might not fix the slap so it just started at 60k? my truck is getting close to 60k
Old 09-27-2007, 03:43 PM
silverado122775's Avatar
silverado122775 silverado122775 is offline
I would not use oil any thicker than 10w30. Using thicker oils will interfere with oil flow and the oil pressure will increase. In a worn engine it may be okay to increase the viscosity of the oil because the bearing clearances have become larger.
2000 Silverado Z71, 5.3L, K&N GenII Air Intake, Y-pipe Exhaust (no muffler), Bosch Platnium +4 plugs, 242k miles and still running.
