Go Back   Automotive Forums Car Chat > Mercury > Sable
Old 09-26-2007, 10:36 PM
vinnie1543 vinnie1543 is offline
Speedometer Problems???
I have a 1996 Sable and all of a sudden not too long ago the speedometer started acting up. When I first start the car and take off the speedometer will either not read anything at all or it will jump around. After driving for approx. 10-15 min. it usually settles down and seems to work fine. It doesn't act up the same every time either. Some days I can drive to or from work and it won't act up at all, other times it will start out working fine and then after I drive it for a few minutes then it will start going crazy. Every once in awhile the car will jerk pretty good like it's either shifting back into a lower gear or missing in a big way. I don't know if these are the results of the same problem or if I have 2 different problems. I am not quite automotive illiterate but I'm no Mr. Goodwrench either. I guess if it's a fairly simple fix I'd like to take care of it myself and save a few $$$, but I don't have a clue as to what would being causing any of this either. Any thoughts or advice would be greatly appreciated. Thanks very much.
Old 09-28-2007, 02:03 AM
reekor reekor is offline
Re: Speedometer Problems???
Change the speed sensor
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 11-28-2007, 08:52 PM
khoist khoist is offline
Does the power steering go out too? I am having a similar problem with my 1998 sable. It only does it once in a while, but when it does the power steering does too, and the sevice engine soon light comes on. Not too experienced with these newer integrated systems.
