Go Back   Automotive Forums Car Chat > BMW > 5 Series
Old 09-26-2007, 07:04 PM
haroldcalvert haroldcalvert is offline
no start
This is a 2001 BMW 523I,I have removed the intake manifold to replace heater hoses, removed radiator and replaced and added new thermostat. Now that it is all back together the car will not start. Help please!!!!!
Old 09-28-2007, 11:59 PM
sidewinder69's Avatar
sidewinder69 sidewinder69 is offline
Re: no start
Need more information than that.
Does it crank over at all or is it completely dead? Could be a dead battery if it will not crank, or just barely cranks and then nothing.
Did you plug all sensor wires back in? If you disconnected the battery, did you reconnect it?
Aren't you that kid my older brother used to throw dog shit at?
Beamer:
http://www.facebook.com/album.php?ai...4&id=761900240
Old 10-01-2007, 06:16 AM
fkhatib fkhatib is offline
Re: no start
Hi
I am having the same problem. Have you been able to solve it out ?
Regards.
Old 10-01-2007, 12:53 PM
Re: no start
Thanks for the reply, I charged the battery and connected it back as it should be. The car turns over, but gives no sign of firing.
All the sensors are pluged in, except to the connection on the radiator on the return, we have not been able to find the wires that should be connected to the sensor. The car has been worked on before we got our hands on it and the person was not very deligent about his work.
The car started before we began work on it, the problem we were trying to solve was loss of antifreeze. The pipe going to the heater(which is under the intake)was melted. We replaced the piping(both in and out) found that the radatior also leaked, so we replaced that, the fan cover was beaten up so we replaced that and we replaced the thermostat(just for good measure)
Old 10-04-2007, 06:16 AM
Re: no start
I know it's stupid to ask but here goes...does it have any fuel in it?
I'm a little concerned about that rad sensor...BMW's are smart and if it cannot detect a sensor it may refuse to start based on that.
Does it come up with any codes on the HUD when you put the key to starting postion, but before you turn it to start it?
Beamer:
Old 10-04-2007, 11:54 AM
Re: no start
The fuel rail has pressure, the car turn over, I have not read the obd yet, i will do that today, thanks
I will recheck the sensor hook up.
It has a sensor on the radiator, which there seems to be no wires on the car to attach, it is on the main return.
Thanks for ur time.
Old 10-09-2007, 11:39 AM
Re: no start
The wiring on the sensor were connected wrong and the main eng fuse was bad, running fine now, thanks
