Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 09-26-2007, 05:02 PM
ATXJennifer ATXJennifer is offline
Problem - Driver Window Only
I can work all power windows and locks perfectly fine - except the drive side button. It will go down no problem but will not go back up.
I have popped it off the door and had to hold the wires and move them around to make it go back up.
Any suggestions on what I need to buy to fix this?
I would appreciate it - I took it to ford and the guy came out and said yea the connector is bad $160 bucks.
I thought you did even test anything and the other button which is the passenger works just fine - I thought maybe the wire was bad.
Please help I don't have cash to lay out to Ford for something like this.
thanks
Jennifer ATX
Old 09-26-2007, 07:03 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Problem - Driver Window Only
Sounds like the technician is probably right that the connector is failing. For their liability and labor rate, they need to replace the connector. However, if you can find someone knowledgeable and willing to do it, you could either have the connection repaired or possibly hardwired, depending on where the loose connection is located.
-Rod
