Old 09-26-2007, 04:11 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Which years...
When did Chevy first go from TBI to SFI/CFI/PFI in trucks?
And which models had CFI and which had 8 seperate injectors?
When were the 4.3/5.0/5.7L engines replaced with the 4.8/5.3/6.0L?
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 09-26-2007, 11:04 PM
horse482's Avatar
horse482 horse482 is offline
AF -Advisor
Re: Which years...
On full size p/u's the last year of tbi was '95. '99 was the last year of the 4.3, 5.0, 5.7 in the half ton p/u's, they still used these engines on 3/4 and 1 tons until '01.
NO 4 N JUNK
1994 GMC K1500 XC 5.7L
2008 Chevy Impala LTZ
Old 09-27-2007, 04:46 AM
Frankp87 Frankp87 is offline
Re: Which years...
I'm not sure when the last year for TBI was, but my 98 Silverado has the TBI on a 5.7L
Old 09-27-2007, 03:33 PM
J-Ri's Avatar
Re: Which years...
Thanks
Old 09-27-2007, 05:54 PM
abaird abaird is offline
Re: Which years...
Yeah, the intro of OBDII killed off the TBI engines. In 96 everybody needed one injector per cylinder so they could shut off fuel if it was missfiring. Your 98 may have a throttle body but it is not TBI. If it is a vortec then it is CSFI(central sequential fuel injection) It has eight injectors in a centrally located box under the intake plenum and each sends fuel down a tube to a poppet nozzle in that cylinders intake runner. With the intro of the third gen small blocks(4.8, 5.3, 6.0) They got rid of that system and just went with injectors that can actually be seen from the outside.
2009 Silverado 1500
2002 Camaro Z28(rebuilder)
2005 Yamaha GP1300R
Old 09-29-2007, 08:43 AM
Re: Which years...
Just found that out Abaird, had to replace the intake manifold gaskets and seen the injector setup.
Frank
1998 Silverado Z71
