Okay im not much of an electrical guy at all try to help me out here and give me suggestions if possible
Yesterday i stalled my car (like an idiot) and when i went to start it back up the starter didnt make any noise the lights on the dash and the fans and everything else came on like i had my foot off the clutch (which i didnt) and i checked the neutral saftey switch but thats okay ive checked the 12v wires and the magnetic switch and all that jazz and im looking over wiring diagrams but its like @.@ anyone had this problem before and do you think i just need a new relay or do i need a whole new starter im peaced off too because it wont start and i gotta go to work tomorrow
~Erik the red~ |
Re: Starter Problems
I had that same problem where it started fine and the next time I went to start it, it did not start at all. So you did check if you were getting 12V from the battery to the starter when someone would turn it over? It can happen but usually starters do not just go out all the sudden. With me, it turned out that up my positive line under the insulation it had corroded. I simpily snipped it, cut the insulation, and bolted it back up. I was having the exact same symptoms you are having too, everything works except the starter. If you have not taken a voltmeter form the battery to the starter and then have someone try and start it to see if it reads 12V under a load, I would definately try that.
SL3000GT IS A GENIUS!! thats exactly what happened and thanks to your incredibly quick(and appreciated) response i went and got a new 12v wire and cleaned up the other little connector thingy and IT WORKED
![]() ![]() ![]() thanks!
~Erik the red~ |
No problem, glad to here it worked out for you.
