Old 09-26-2007, 01:19 PM
Galuple Galuple is offline
turn signal problems
i recently got into a fender bender with an xtera and had to have the front bumper and hood replaced. since i've gotten my 92ex back from the shop i've noticed that the left turn signal is flashing twice as fast in the back and not at all in the front. does anyone have any suggestions? would this be a quick fix?
Old 09-26-2007, 01:30 PM
Copytech99 Copytech99 is offline
Re: turn signal problems
The system will flash quickly to alert you of an open filament in one of the bulbs (hopefully) Check the bulb that is not flashing at all first.
Old 09-26-2007, 01:31 PM
so a quick replacment of the bulb ought to do it?
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
did you replace the bulb? Usually if a front turn signal is out, the rear will flash like that. And if a rear turn signal is out, the front will flash like that. Otherwise, check the wiring harness to see if a wire was cut.
haha guess I was too slow to respond.
Old 09-26-2007, 01:33 PM
right i think that this should fix it. thanks guys!
