Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 09-26-2007, 10:06 AM
fastkev fastkev is offline
2000 Venture wheel hub assembly. (front)
I'm going to replace this myself and was wondering if I need a special puller or what to get this thing off. If I do maybe someone can post me a link to what it looks like? Also, if the hub does need pulled off what about putting it back on? Thanks.
Old 09-30-2007, 05:15 AM
kornjulio kornjulio is offline
Re: 2000 Venture wheel hub assembly. (front)
I did my front wheel bearings this past summer...you shouldn't need a puller - but you do need a 33MM socket for the axle nut....once the nut is off and the hub bolts removed; tap the axle back in towards the trans and tap the hub outboard....youll be able to pull the hub the rest of the way off....
