Go Back   Automotive Forums Car Chat > Cadillac > Seville
Old 09-26-2007, 07:51 AM
93SHOcarguy 93SHOcarguy is offline
94 STS Clunk in the back
I'm hearing a loud clunk in the passenger rear when I hit a bump. I thought it was a muffler or pipe hitting under there, but we put it on the rack yesterday and found nothing. All is welded up and solid. Our next logical thought was the strut mount? I've looked online some this morning though and can't find anyplace that says anything about a rear strut mount for a 94 STS. Does this mean the whole strut needs replaced or is there something else to check for. We did find the air ride unplugged when we were under the car, and I left it that way. Not sure if this has any bearing on it or not, I doubt it.
Any suggestions would be great. THANKS ! ! !
Old 09-26-2007, 07:00 PM
caddydaddy caddydaddy is offline
Re: 94 STS Clunk in the back
The rear is a air shock, not a strut. The most common source of the noise is the sway bar end links that connect the sway bar to the chassis. It might not hurt to also replace the sway bar bushings if they are worn. Last I checked the end links were around $70 a pair and the bushings were around $10 a pair.
2000 Cadillac STS
2005 Cadillac Escalade
2008 Triumph Sprint ST 1050 ABS
