Old 09-26-2007, 07:21 AM
AndrewG AndrewG is offline
93 Caravan water pump
Hello all.
I am being lazy by posting this. My 93 Caravan (140,000... 3.0L V6) has developed an overheating issue. I was looking to find out if the water pump is driven by the timing belt, and if so, if anyone had the timing diagram and or any helpful hints. I am no stranger to this type of repair, but I do know the value of others input. I am guessing water pump because the radiator is full and has good pressure. It just gets hot during normal operation, and up till now I have had no problems in three years.
Thank you in advance.
A
Old 09-26-2007, 08:22 AM
earlyrizr earlyrizr is offline
Re: 93 Caravan water pump
pump is driven by the timing belt,but has the thermostat been changed lately?cheap and easy to replace, good place to start with. Also a plugged rad can cause overheating and still be full.
Old 10-10-2007, 08:09 AM
The thermostat was bad (stuck open). However the timing belt was so loose it could not adequately drive the pump. I changed the pump anyway and all is well. EXCEPT: Now it smokes at long lights (in other words on idle) from the exhaust. Maybe the valves are shot. Worst case I will just switch to synthetic oil so you at least don't SEE the smoke. Thanxs for your input.
A
Old 10-10-2007, 08:50 AM
smoking at idle usually caused by bad valve seals,can be done with the head still on the engine
Old 10-10-2007, 09:11 AM
So A valve seal is not the ring that it seats on I am guessing? Are they under the valve cover? I guess I will get in the Haynes manual and read up on it a little.
